Fuel tank level
Old Mar 13, 2018 | 08:44 AM
dmout53's Avatar
dmout53
Fuel tank level
Can you cause damage to fuel pump if you overfill your tank, top it off ?
Old Mar 13, 2018 | 09:24 AM
2trux's Avatar
2trux
The short answer, No. The long answer, No
Old Mar 17, 2018 | 01:46 AM
Skauber's Avatar
Skauber
But you can flood and soak the charcoal canister, which is easier and cheaper to replace than a fuel pump, but still a $ 250-300 part...
Old Mar 20, 2018 | 09:01 AM
2trux's Avatar
2trux
I did not know that. Is that because of a vent that feeds back into the fill tube?
Old Mar 20, 2018 | 10:15 AM
alloro's Avatar
alloro
No it happens when fuel gets into the EVAP vent hose. There is a valve which is supposed to prevent that from happening and as long as the valve is working you're okay. But if the valve fails or leaks then the fuel will fill the EVAP hose.
Old Mar 20, 2018 | 01:13 PM
Skauber's Avatar
Skauber
It can still happen with a working valve if you overfill it to the point you see fuel in the at the top of the filler neck. Some people like to do that. I don't believe it kills the canister instantly, but it shortens the life of it.
IppoJ
13
Oct 15, 2016 09:32 AM
Borgia
Sep 20, 2016 08:25 AM
lilernie
16
Dec 31, 2009 05:52 AM
ldcattle
Jan 5, 2009 03:44 PM
fireman_19
Aug 31, 2005 03:24 PM
