2009 thru 2012 2.5L - Coolant air bleed valve?
I'm overdue for replacing antifreeze. There is a coolant air bleed valve that the shop manual says to open on refill. But it does not say HOW to open it. The valve is on the end of a short stub hose that is attached to the water distributor, which is on the driver's side of the engine, higher up, about over the bell of the trans.
My question is... how does it open? The bleed valve is a black plastic cylinder, which has two notches on its top outer edge. Inside the cylinder is a black plastic piece, obviously a separate piece, that has sort of a flat-blade screwdriver slot in the center of it. On its outer edge, it has a small projection, that fits in one of the slots of the cylinder's edge, as if the projection was an indicator.
I'm wondering if one inserts a screwdriver, and turns it slightly CCW to open, to move the inside piece's projection to the other side of the slot. It won't be much turning movement at all, as the slot is of a pretty short length.
Do I have it figured out right? Or does it work completely different? I really don't want to break it...
Like this?
Photobucket
The thread (talking about the 2.5V6 in Fusion), that pointed to it said it just unscrews CCW, the projections and slots are just a semi-captive design to stop it inadvertently coming loose.
https://www.fordfusionforum.com/topi...-valve-on-25l/
Photobucket
Doc
42
03-25-2013 09:04 PM
ErrorS
07-17-2007 09:04 PM
firejax1
10-08-2002 06:32 PM
explorermike
12-27-2000 09:59 PM
