2002 Excursion - White Elephant
Old Mar 16, 2018 | 06:22 PM
Jeremyh Ford's Avatar
Jeremyh Ford
V's are in! It took me about 4.5 hours including clean up to get them in and back together. Taking off the bumper is a must and would be difficult but yourself. Also, large ratchet straps are required. Made moving the axle into position a lot easier.
The U bolts from ATS we're really long. I might trim them off when I add the turn stop.
While I was there, I replaced the missing bump stops.
I didn't get shocks because I wasn't sure of the condition on the existing. Turns out they weren't smoked, but on the way out. I'll replace those when I get my spacer and wheels next week. Spacers FINALLY shipped today after 3 weeks from BORA.
Fronts on both sides we're 22.25" and rear we're 24.25". After the install, fronts we're 24". So I'm pleased with the outcome.
Some before and after shots
Old Mar 18, 2018 | 05:19 PM
Jeremyh Ford
Lubricated the front hubs today. ABS light is on. I'll try resetting the system and see if that takes care of the issue.
I also got new Michelin AT2 mounted in my new wheels today.
Driveability has improved with the new springs. Can't wait to get the new tires on .
New shocks and steering stabilizer will be here tomorrow.
Old Mar 19, 2018 | 05:45 PM
wpnaes's Avatar
wpnaes
Might as well pull the abs sensor on top of the rear pumpkin. Make sure there is a good elec. connection and clean the magnet.
Old Mar 21, 2018 | 07:43 PM
Jeremyh Ford
New BORA spacers came in today along with new shocks and steering stabilizer. New tires on the wheels waiting in the garage.
Only one out of four spacers fit.....
(Edit) Update - Lenny Stahl and I spoke and Motorsport Tech is going to make it right. New set en route next week.
Old Mar 29, 2018 | 12:12 AM
Vanniek71's Avatar
Vanniek71
Nice work, I think I’m gonna need to replace my drag links, I’m clunking like mad
Old Mar 29, 2018 | 07:20 PM
Jeremyh Ford
It's a worthwhile fix for under $70 and 30-45 min
APDTY 016412 & 016413 Anti-Sway Bar End Link Pair
Old Mar 29, 2018 | 07:26 PM
Vanniek71's Avatar
Vanniek71
Thanks for the info, will get those ordered. I’m also thinking about doing all the bushings etc with the poly bushings from suspension.com. When I was redoing the front diff seal (slammed a rock out Elk hunting) I noticed they are all pretty beat
Jeremyh Ford
Wheel spacer saga continues....
Was promised today but no dice. Apparently a machine went down.... Last time it was the weather. Disappointing really. At least I got a phone call.
I'm going to press the studs out/back in myself as I don't have any faith at this point they will actually be delivered. 2gs worth of wheels,tires and shocks ready to go. Alignmnet scheduled for tomorrow.
I just need to make something happen.
Old Mar 29, 2018 | 07:28 PM
Jeremyh Ford
I couldn't believe how much quieter the ride was. You'll wish you would have done it sooner.
Old Mar 30, 2018 | 01:59 PM
Jeremyh Ford
Well, I managed to get everything on without a hitch. The ride is so much better. New shocks and steering stabilizer. Should have done the V swap and wheel / tire package sooner.
I also removed and cleaned the ABS sensors before installing the spacers. That fixed the light issue.
Currently getting a front end alignment and oil change.
Old Apr 3, 2018 | 03:22 PM
Jeremyh Ford
Changed transmission fluid and filter over the weekend. Old fluid was a dark cherry color. Nothing to speak of in the filter or magnet. Looked normal.
I also changed out the rear bump stops.
Did I mention it drives so much better? Who would have thunk it?
Old Aug 30, 2018 | 02:16 PM
Jeremyh Ford
Needle bearing on drivers front starting talking to me this week. After 200k, I figure it's time to change out more parts! Ordered new front hubs from SKS, Dana U-Joints, Proforged Ball Joints, and misc seals required on the change. What fun! Total part cost = $632.00. Quote from the local dealership was $3k. I'm sure there will be a blood letting, but it beats the bleeding that would occur from my wallet.
Still love driving this rig.
Old Aug 30, 2018 | 04:57 PM
  #28
wpnaes's Avatar
wpnaes
Yeah, but the dealership installs gold plated bearings.
Old Aug 30, 2018 | 07:41 PM
  #29
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
They sure think they do...
Good one, Sean.
Old Aug 30, 2018 | 08:03 PM
  #30
npe3484's Avatar
npe3484
Trailering
I did the same job recently. If you happened to order new needle bearings and yellow hub o-rings, you won't need them. They were already installed on the SKS hubs that I got from RockAuto.
