Transfer case question
Old Mar 10, 2018 | 08:42 PM
jsc83's Avatar
jsc83
Hey guys
I got a 67 F250 4x4 recently and I'm working through all the systems to see what's good and what needs work. The t case seems to work, but there are no indents for the various positions. It seems that you have to know where the different settings are located. Is that normal operation? Thanks.
Old Mar 11, 2018 | 09:17 AM
willowbilly3's Avatar
willowbilly3
Dana 24? Hard to find parts for those except bearing and seal kits. I changed to a 205 to avoid the search on my old 4x4.
Old Mar 11, 2018 | 11:57 AM
Oldsch's Avatar
Oldsch
No probably not normal. On mine I have to give the shift lever a bit of a bump to get it moving and there definite stops for each gear/range. Its not a smooth piece of machinery for sure....more of a tractor part. but you should be able to feel the detents.
There are two shift rods going in to the front of the transfer case, inside the case there are ball bearings and rods that fall in to grooves in the two shift rods. That is what defines the shift pattern. Its pretty involved to get in there..... Probably check the linkage and shift lever first make sue nothing is binding. Then maybe live with it until you rebuild the t case someday.
Old Mar 11, 2018 | 01:16 PM
jsc83's Avatar
jsc83
Thanks guys. Appreciate the help. Not sure I like the answer, but definitely appreciate your advice.
Old Mar 12, 2018 | 09:44 AM
cstoyer's Avatar
cstoyer
If the linkage checks out make sure the two hex head bolts that retain the spring and detent ball for the shift rods are present on the case in valley area between the case to frame mounts. If they are not then that would cause the shift lever to feel like there is not a positive location for each drive mode. This would also cause it to want to come out of gear and go into neutral. If they are there then take them out and make sure the spring and detent ball are still in there and the spring is not broke. Other than whats been mentioned you will have to dive into the case to see what else is going on. Not super difficult to do but if you find something internal that is bad your going to be in troubleand may have to call it a day on that case.
As willoybilly3 has said you can still get the seals and bearings, which I did to rebuild my D24 before finding a divorced 205 to replace it. Other than that the only other thing you can get is an adjustable detent bolt and spring set up that is after market.
cstoyer
Old Mar 12, 2018 | 01:10 PM
jsc83's Avatar
jsc83
cstoyer
That's very helpful. Thanks for your assistance. I will check that out next time I'm under the truck.
4mr11C20
Jul 24, 2013 05:06 AM
cwt7691
Sep 19, 2007 06:20 AM
PaloStang
1966 - 1977 Early Broncos
Mar 5, 2005 09:55 AM
