Passenger window motor, only down on one switch.
Old Mar 10, 2018 | 02:49 PM
jttmoguls's Avatar
jttmoguls
So I hit a issue and didn’t have much luck searching, so before I go crazy throwing parts I’ll ask and hope for help.
Yesterday was going to lunch, coworker in the passenger front seat rolled window down to talk to someone. Stopped halfway, then tried rolling up. Nothing. Went to roll down, went all the way down, but no back up. Same with using drivers side switch. Figured bad motor, so got new one today from parts store. Put the new one in and same problem. Will only run in the down on the passenger switch, and then there’s nothing on the drivers switch (down or up). Could a bad drivers switch cause both sides not to work? All other windows work fine. Wiggled each wire loom on each door looking for a bad wire/splice and no luck.
Thanks for any insight!!!!!
Old Mar 11, 2018 | 11:27 AM
cameeks's Avatar
cameeks
I would take the switches apart and clean the terminals. My mirrors were doing the same thing and after some scotch brite and dielectric grease everything was better.
Old Mar 11, 2018 | 12:53 PM
ShelbyHauler's Avatar
ShelbyHauler
My rear passenger window will go down with the rear passenger switch, not up. I can make it go up from the drivers master switch. I took the front passenger switch and used it to try to raise the rear passenger window, but still no go. I replaced the drivers master switch as suggested here, but no change. Least I can get mine up from the drivers master switch.
Old Mar 12, 2018 | 09:14 AM
alloro's Avatar
alloro
The power for the window runs in series through both the driver's master switch and the passenger switch. So if there is an issue with either switch the window will not work properly. I'd start with the passenger switch since it's less complicated and expensive.
Old Mar 12, 2018 | 09:26 AM
cameeks's Avatar
cameeks
Why does everyone like throwing money at things? Have you even pulled the switches and had a look at them? You can check them with an OHM meter. Also you can pop them apart and clean the copper contacts on the inside(*edit.... Now thinking about it cant remeber if it was just buttons or a copper plate. I would still look first). All of that is free. Also you can get a friend to help you check the wires from the drivers door to the other door with the meter to see if there is a break in the wire.
Old Mar 13, 2018 | 10:58 AM
alloro's Avatar
alloro
Who's doing that? The OP hasn't replied to anything with his next steps yet.
Old Mar 13, 2018 | 12:09 PM
ShelbyHauler
Returned my part to Amazon. The replacement master's Auto-Down for the driver's window did not work. And it did not resolve the issue.
Old Mar 16, 2018 | 09:25 AM
D3thM3tal's Avatar
D3thM3tal
I'll help him with that next week - we can pull switches from my Excursion to rule out any bad parts as well.
A thought - does the switching reverse the polarity of the power? IIRC there are just two wires that go to it and if that is the case, something has to be just reversing the polarity. If the window will power down, but not up, that would mean that there is proper power and ground and that the issue is at the switching, right?
Just thinking out loud-
Krazyhorse93
Nov 13, 2017 08:22 PM
Nicmike
Jul 28, 2014 10:05 PM
hapkidoman
Nebraska Chapter
Jan 17, 2009 04:25 PM
berry1234
Jun 21, 2008 09:18 PM
wileecoyote76
1997 - 2003 F150
Oct 28, 2004 08:53 AM
