Swapping a c6 from a 68-72 into my 74. Discovered the speedometer cables were different between the 2, do they make a speedometer cable for that swap? What are my options?
Casting number for the trans case, dates to 1966 when the C6 was introduced in cars. Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
Trans case same: 1966/71 FE Passenger Cars (no FE's in cars after '71), 1968/73 F100/350 360/390.
I used one of these when I put a 70s divorced T-case into my 59. You have to get the right gear and a clip. Remember, the gears for left or right side speedometer cables are different.
