Sponsored by: Real Truck
Crazy noise
Old May 2, 2018 | 10:50 AM
painandgain's Avatar
painandgain
if it correlates with bumps in the road, its sway bar links. I like to check the cheap stuff first
Old May 7, 2018 | 09:31 PM
electod's Avatar
electod
Ok so I purchased new radius arm bushings, ball joints were bad new seals for axles and hub, new u-joints also, track bar bushings, started working the job today, cannot find any info on press to install new radius arm bushing in the housing the rears are easy, any help on tool info would be great, also a part number for the new style axle seal would be great
Old May 8, 2018 | 07:29 AM
RedTonka07's Avatar
RedTonka07
link for parts
Use your vin here Auto Value to look up part numbers for truck. I used this when I did my work recently.
Old May 8, 2018 | 07:33 AM
RedTonka07's Avatar
RedTonka07
How-To Install a Bushing Without a Press - Suspension.com
This looks cool for bushings without a press.
Old May 9, 2018 | 01:12 AM
brian42's Avatar
brian42
Veteran: Navy
I had a phantom clunk that I couldn't find. Turned out to be my front swaybar end links.
adgjqetuo
Jan 19, 2020 10:05 AM
Ckasten99
2009 - 2014 F150
Sep 19, 2018 04:07 PM
joejackF250
Dec 27, 2017 07:39 PM
jblueguy
1997 - 2003 F150
Jan 30, 2013 06:56 AM
SilverBullet131313
Dec 6, 2005 08:49 AM
