Sponsored by: Real Truck
Replacing tube side steps
Old Mar 9, 2018 | 05:15 PM
woody367's Avatar
woody367
I ripped the factory tube side step off my 04 extended cab F250. It got caught on a down tree limb while snow plowing and the bolts pulled out from the brackets. Does anyone know if any of the aftermarket step bolt directly up to the factory spots on the rocker panel? thanks
Old Mar 11, 2018 | 12:07 AM
woody367's Avatar
woody367
Anyone have any idea?
Old Mar 11, 2018 | 09:40 AM
SnowPlowDriver's Avatar
SnowPlowDriver
I have two different brands that use the factory mounting holes. I boards is my favorite. Iboard.com
Old Mar 11, 2018 | 10:30 AM
DogRidesInBack's Avatar
DogRidesInBack
I found some inexpensive steps I'm considering for my rig. I just assumed they will bolt up to factory locations, so now I am wondering if they do... Being they are inexpensive.
ETA: Pic of the ones I'm looking at are in post 125 of the thread in my signature.
Old Apr 2, 2018 | 08:49 PM
Hyperbiker's Avatar
Hyperbiker
I had the drivers side come loose from rot on the underside, I bought stanless steel bolts and SS fender washers w/ nylock nuts and drilled up thru running board. Not as ugly as I thought it would be because the bolts recessed themselves into the rubber grips
Old Apr 2, 2018 | 11:34 PM
SuperDutyScaler's Avatar
SuperDutyScaler
I have Westin platinum series on my 2004 and the 1/4" brackets bolt in the same holes the factory ones were bolted to. I did use metric stainless bolts from boltdepot.com though when I installed them
Ron94150
Oct 27, 2016 07:27 PM
f-trucker88
Oct 5, 2013 02:39 PM
f350Super99
Nov 9, 2012 04:49 PM
Heff-7.3PSD
Apr 12, 2008 01:09 PM
jpegg
13
Apr 20, 2004 01:55 PM
