Sponsored by: Real Truck
running board install help
Old Nov 8, 2012 | 11:20 PM
f350Super99's Avatar
f350Super99
I picked up a used set of factory tube steps for my 06 crew cab f350 they did not come with any thing to fasten them with?
Any one tell me whats needed to install these on my truck?
they are tube steps with 3 brackets per side again the are factory oem
thanks
Old Nov 9, 2012 | 12:07 AM
Pickupmanx2's Avatar
Pickupmanx2
They use 2 or 3 bolts, on the inside of the door frame, underneath obiviously, they are a metric bolt, I would go to a Ford dealer and just order the mounting bolts, or borrow one from a friend who has running boards and go to your local flavor of hardware store.
Old Nov 9, 2012 | 05:47 AM
redford's Avatar
redford
FTE Leadership Emeritus
The brackets bolt to the pinch weld area.
Old Nov 9, 2012 | 10:51 AM
f350Super99
I wanted to know if you need any thing special or just bolts and nuts?
Old Nov 9, 2012 | 11:53 AM
Bigpipes 35's Avatar
Bigpipes 35
Nothing special needed.
Old Nov 9, 2012 | 12:53 PM
SC_Hoaty's Avatar
SC_Hoaty
Not sure about the factory ones, but the aftermarket ones have nuts, bolts, washers, and brackets. You bolt the brackets to the pinch weld area like reford said. For the upper holes in the brackets, they give you a clip that installs through a slot and had the nut attached to the back side (this beats trying to hold the nut in the blind area. The lower bolt holes on the bracket are aligned with existing holes in the pinch weld area. After you install the brackets, the running board or nerf bar justs bolts to the brackets.
For the stuff you bought, are the brackets part of what you got? If so, you just need nuts, bolts, washers,....
Old Nov 9, 2012 | 12:59 PM
f350Super99
SC_Hoaty, yes i have the brackets just not the bolts and hardware
I got under the truck and seen the area your talking about with these brackets it imposable to hold a nut on the back side I make a templetof the location thinking fastenal might be able to help me out with some thing
Old Nov 9, 2012 | 01:07 PM
Punisher29073's Avatar
Punisher29073
Mine used the nuts that had a clip on them to hold them to piece of flat metal. The bolts are regular. I would think that fastenal would have something that work. Otherwise they would be fastensome. They may call them fender nuts?
Ryan
Old Nov 9, 2012 | 01:17 PM
SC_Hoaty's Avatar
SC_Hoaty
I think they call them clip nuts. They look kinda like this:
Make sure the center of the nut/hole to the edge of the slot/clip frame fits your application.
Old Nov 9, 2012 | 02:18 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
We have the 05 style tube running boards on our 02 F250 and they mount on the pinch weld. We just used a nut lock washer bolt. We have had them for a year down bumpy backroads no problems.
Trav
Old Nov 9, 2012 | 04:02 PM
f350Super99
I was able to go to Fantenal and get what they call "U" nuts (number 0162842) 5/16-18 looks similar to what SC_Hoaty posted, I also found them afterwards at the local Ace Hardware when I went to get bolts
Link: http://www.fastenal.com/web/products...ex?sku=0162842
used a total of 10 "U" nuts the front backet only uses one the rest use two, the lowers I used 12 grade-8 bolts, nuts & washers 3/8x1
in case any one else down the road needs this info here it is
thanks for the help guy
Old Nov 9, 2012 | 04:49 PM
SC_Hoaty's Avatar
SC_Hoaty
Link: 5/16-18 Panel Range .025"-.150" Center 27/32" Extruded U Nut | Fastenal
Glad you were able to find the right hardware.
back at ya!
Ron94150
Oct 27, 2016 07:27 PM
bweb
Feb 26, 2015 07:17 PM
Scratch
Jan 7, 2009 12:15 PM
gagnonconsulting
Jul 20, 2007 04:15 PM
biglee
1947 and Older Ford Trucks
Aug 15, 2006 01:43 PM
