Shock Recommendations
Old Mar 9, 2018 | 03:15 PM
mountainrev's Avatar
mountainrev
It's obvious that my F100 needs shocks. I don't plan to haul anything too heavy, although I might possibly tow our camper (~3,000 lbs, 200 lbs. tongue weight) occasionally (but not far). Any recommendations? How hard of a project is it? Thanks!
Old Mar 9, 2018 | 04:59 PM
HIO Silver's Avatar
HIO Silver
Difficulty Level: Easy
Recommendations: Bilstein HD or Monroe Gas Magnums
Old Mar 9, 2018 | 07:21 PM
enrand's Avatar
enrand
Shocks
x2 on Monroe Gas Magnums.
Cheap, stiff compression, made in USA I think.
Used them on several trucks.
Old Apr 16, 2018 | 02:12 PM
mountainrev
I wound up installing Gabriel ProGuards. Should have gone with the recommended Monroes. Here's why: The Gabriels have an upper tube covering the shaft, whereas the Monroes don't. With that upper tube, it's extremely difficult to get the top of the shock to line up through the small hole due to the tight squeeze next to the coil spring. Got them on Rock Auto, which indicated they would fit. Guess they did, but barely.
So regardless of what shocks anyone goes with, I'd recommend making sure they don't have a top tube for the front shocks.
Old Apr 16, 2018 | 05:24 PM
KOT390's Avatar
KOT390
I went with KYB from Rockauto. Fit and ride great. Easy job.
KOT390
Old Apr 16, 2018 | 11:19 PM
351Cleveland C4's Avatar
351Cleveland C4
I went FROM gas-magnum shocks TO KYB gas-a-just. There Was a noticeable improvement in ride quality. Especially on washboard roads.
Gas magnums are fine shocks. But if you drive a lot and are looking for a little more comfort, get something better.
Dr G
16
Jan 22, 2020 02:11 PM
Falconater
Apr 17, 2018 10:43 PM
Flhtc
Dec 21, 2015 12:41 PM
marine1200
1947 and Older Ford Trucks
Jun 18, 2012 09:02 AM
Storm
May 23, 2007 04:06 PM
