Fuel Pump Problem
Old Mar 9, 2018 | 02:08 PM
49m47's Avatar
49m47
Fuel Pump Problem
Greetings
I try to start my truck every 2 weeks but sometimes.... Well life gets in the way. If it sits for much more the 2 weeks the reeds in the fuel pump reeds stick closed. I blow air through and they open back up. I'm calling them reeds because I don't know the official name and it sounds better then the circular rubber flap thing.
Has anyone else had a problem like this?
Old Mar 9, 2018 | 02:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Try adding a little Marvel Mystery Oil to the gas. Those circular rubber flap things are check valves.
Old Mar 9, 2018 | 03:32 PM
moejr's Avatar
moejr
Also known as, mechanical fuel pump diaphragm.
Old Mar 9, 2018 | 07:24 PM
FortyNiner's Avatar
FortyNiner
How old is the fuel pump?
Old Mar 9, 2018 | 09:08 PM
49m47's Avatar
49m47
It was a new old stock that I got from a friend. So I don't know the exact age. I have had it on the truck for 3 years.
Old Mar 10, 2018 | 06:06 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Unless it was made recently, it probably isn't ethanol resistant materials
Old Mar 10, 2018 | 02:51 PM
Mixer man's Avatar
Mixer man
If it's a NOS pump it probably has neoprene check valves and impregnated diaphragm. These won't hold up well with ethanol. Newer pumps will use a variety of elastomers such as Viton, Nitrile, and Buna-N.
vidaliaman
Sep 11, 2025 09:37 AM
clinkfield
Aug 23, 2018 07:40 PM
