Sponsored by: Auxito
Transfer case grinding
Old Mar 9, 2018 | 11:46 AM
Mike Killian's Avatar
Mike Killian
Got a 2001 f150 5 speed 4.6 with a borg-warner 4406 transfer case no matter what drive I'm in or if the tcase is in neutral it has a grinding sound coming from it power steering pump is a part timer but when it does work the grinding becomes louder any thoughts on this?
Old Mar 10, 2018 | 09:31 PM
enriched&beyound's Avatar
enriched&beyound
Might be the throw-out bearing for the clutch?? might be other things too?? Sound has a way of traveling making it seem like its coming from one area only to be another culprit. I would get a mechanics stethoscope and try to isolate where its is coming from.
Try this... take the serpentine belt off and start it....If the sound is gone , it then is something on the belt drive system. If it is reduced, you may have multiple issues. It might then be come easier to zero in on what is making the noise. It could still be the T-case or it might be the flywheel ....or just a heat shield rattling...
Old Mar 11, 2018 | 02:49 PM
Mike Killian
Was gonna change the tcase fluid and buy a used pump see if that helps just don't wanna run and get a new t case only for it not to fix it
rustyrudder
May 8, 2015 06:09 PM
Scott598
Jun 2, 2013 07:11 PM
New Guy 89
Feb 5, 2011 10:13 PM
jlsk8ter
Oct 31, 2010 08:01 AM
lestro
Jan 17, 2010 09:48 PM
