05 Excursion Diesel - Intermittent No Start
I'm mostly a lurker. Haven't posted much. But I'm concerned something bad is about to happen to my truck. I just got it out of the shop. It blew its head gaskets for the second time since I've owned it - and it was bullet proofed/studded and fire ring heads the LAST time I fixed it. I never thought it would be here again. But it started pressurizing the coolant again a few months ago and when we took it apart the heads were destroyed again. I think it happened again when a production company I was working for filled it up with unleaded and I then drove it for a hundred miles or so and got it hot. - 6 months later - I was buying heads again.
Now, about a month or so out of the shop I've got some electrical gremlins starting. Ever since coming out of the shop the starter was dragging and I had some hard / long starts. About two weeks ago, the FICM blew up... and it was a Bullet Proof Diesel 6 phase power supply on the FICM. It died while driving. Blew the 50a fuse. After replacing the FICM under warranty it seemed to still be starting a little slow - with GOOD HPOP pressure (500 to 600 while spinning the motor. I had the batteries tested (they are decent AGM batteries that were less than a year old) and both tested bad so I replaced them both under warranty. To me, it seems like it is STILL spinning a bit slow for new batteries but it is charging up to 14.5 when running. I found my 1/0 ground straps could use some tightening at the battery lugs and they also needed some cleaning up.
It has some minor modifications. EGR delete, Head Studs, Fire Ringed heads, 58v FICM, state 1 turbo kit with a wicked wheel, Air Dog 165 fuel pump, programmer/monitor on the highest tune, 4" Turbo back exhaust, cold air intake, aluminum intercooler piping, coolant filter, 250a alternator, 1/0 ground straps to both batteries, frame, body and alternator.
So, yesterday I hopped in it to head home, hit the key and nothing - ignition/stereo came on, fuel pump running, key to start and no joy. Running a mental check list and immediately thinking neutral safety I pulled it down into neutral and it fired right up. - So I immediately looked under the dash to see if the shifter bolts were coming loose - and they were NOT. It started fine the rest of the day yesterday (shut it off for fueling then at a friends house). This morning I jumped in to start it (it was cold this morning) and nothing again. Pulled it into neutral. Nothing. (same - stereo on, glow plugs cycling, fuel pump running). Put it back in park, wiggled the shifter, tried neutral again - nothing. It was dark and I couldn't remember where the starter line ran on the passenger side so I climbed underneath with a screw driver and shorted the terminals with the ignition on and it spun up and started. Now the rest of the day (I just tried it again after its had time to get cold) and it is starting fine.
My diesel guy says I need to put a new motorcraft starter in it. He said hes heard of the windings going bad on the starter and it starts taking out electrical components. This is scaring me with the recent FICM blow up, the batteries, etc. But before I go buy a $400 motorcraft starter I figured I would ask here and see if anyone has any suggestions and/or agrees/disagrees. He also said the neutral safety may be going bad inside the transmission here - though I read on here that those hardly ever go bad. I DID spin the starter until I killed the batteries the night the FICM died so I guess its possible that I've damaged it. Plus its at 250k miles on the original starter. So, maybe I'm due. I'm just looking for some suggestions/recommendations on other things to check.
thanks for reading
Ed
Some ideas! Thank you. Will do!
That was probably over a minutes worth or so?
Windings do go bad and can do funny things. I've seen it on several large 4 wheel drive tractors over the years.....not pretty when it takes out the GPS
That is long enough to overheat these starters, which is why we tell folks when priming the oil system after work on the HPO side you don't go over 20 seconds cranking with cool down time in between....just sort of a rule of thumb.
Find yourself a good used 6.4 starter
Is the 6.4 starter any different than the 6.0 starter? Is it an upgrade? Like using 6.4 oil fittings and such?
.....quicker start upDirect bolt up, nothing to change really
Burned discolored terminals. Starter was dragging. Recently smoked a FICM power supply. Wouldn’t be at all surprised to find burned windings in it causing all my eectrical gremlins!
And my old starter terminals were deeply discolored from heat.
Between my new Motorcraft 6.4 starter (that was $150 cheaper and no core charge) and new AGM batteries. Excellent upgrade! Thank you!
It's really nice up here in these parts when it gets down to zero or colder. Kids truck pops off in 2 seconds.
