1983 Ford F100 engine replacement
Old Sep 16, 2003 | 02:39 PM
mach10533's Avatar
mach10533
I want to replace my old underpowered 302 in my f100 with an engine from the 90-93 ford mustang. I figure this will be the chapest way to add a little kick to this truck, but I am not sure if I will be able to bolt all of my accessories of of my existing engine onto a newer block.
Can anyone share any info and experiences.
I also would like to know if I can but the carbureted intake on this EFI type engine. I believe I can but dont know for sure
Thanks
Old Sep 16, 2003 | 05:52 PM
NiteMan69's Avatar
NiteMan69
hey there.....
Just be careful for what you wish for...
I did the same for my bronco. Had a 302 and swapped it for a 92 H/O 302 from a mustang. Higher HP and Torque but it kicks in at a higher RPM range than the truck would. This is due to the type of cam. A truck cam has low end torque. The car cam, which pulls higher rpm's, has a higher rpm curve for HP and torque. I just wish someone told me that before i spent all that time with the swap. The pull is just not there from what i had. If you want to swap go for another truck motor. Or just call Jegs or Summitt and tell them what you have and have them fit a bigger than stock cam. You will see a bigger difference than throwing in a mustang motor.
Good luck.
Glen
91 Nite Bronco 302
33" w/ 3" Rancho....
Old Sep 18, 2003 | 11:46 PM
mach10533's Avatar
mach10533
thanks for the tip
The reason I want a new engine is because the power on this one sucks. 0-60 accel sucks and 40-65 accel sucks. Also the truck really loses pwr on hills. It is a light 2wd truck it should perform better. There is two cylinders with low compression of 90 lbs and the rest with 115-120lbs. It also needs a crank because it had been knocking for a while and has a low oil pressure at operaating temp. It has a new 2bbl carb. The engine runs great, it does not miss but it is time to get a little more power.
Anyone got any suggestions on a way to get decent but not hod rod power at the lowest price. I am thinking of maybe a new crank, cam , and heads or either getting a mustang engine. I really wont be towing much with this truck so the towing tourqe of a truck engine wont matter much.
Any ideas please reply
Specs
83 Ford F100 2WD
5.0lL engine with AOD transmission
stock engine
performance exhaust
Old Sep 19, 2003 | 12:05 PM
fishin1976's Avatar
fishin1976
Find a 351w w/4bbl, you won't need to do anything to it to get decent power. (and cheaper than heads, porting, cam, intake, etc that you would have to do to a 302)
Old Sep 20, 2003 | 11:09 AM
mach10533's Avatar
mach10533
would all my acessories such as water pump and all my brackets fit from the 302 to the 351. Would the ignition system plug up to the 351 dist.
ryan73ford
Feb 9, 2017 04:59 PM
MWALTER
Jul 30, 2013 08:31 PM
task24
Feb 26, 2012 03:05 PM
uni62
Jan 29, 2008 04:04 PM
motormustard
May 3, 2006 05:18 AM
