Sponsored by: Real Truck
Please Help, mechanically challenged
Old Mar 6, 2018 | 05:03 PM
Jonathan Rhodes's Avatar
Jonathan Rhodes
I just changed my plugs and the drivers side valve cover. Now my truck is running really rough and shifts hard. I have a 1999 F-250 Super Duty XLT with 187,000 miles on it
Old Mar 6, 2018 | 06:50 PM
Super Duty Dev's Avatar
Super Duty Dev
Trailering
Is your truck's check engine light on? Do you have a code reader? Look for a misfire code. You may also want to check the gaps on your spark plugs. When installing them it is easy to bang the tip of the ground electrode causing the gap to decrease.
Old Mar 6, 2018 | 06:54 PM
Jonathan Rhodes
okay thank you. Im getting a code reader now
Old Mar 7, 2018 | 05:38 AM
Deuce40s's Avatar
Deuce40s
I don't know anything about your engine, but I wonder if the plug wires are in the wrong order. Although it seems like it would barely start if that was the case. Maybe one of the plug wires isn't seated all the way. You could have also damaged a plug wire and it's not getting full juice to the spark plug. I've done this before and it destroyed my torque converter. Be careful.
2003rrangerr
1983 - 2012 Ranger & B-Series
Aug 29, 2012 07:46 PM
josiemarie13
Modular V8 (4.6L, 5.4L)
Nov 23, 2008 10:47 AM
bcmakay
1997 - 2003 F150
Feb 17, 2007 07:40 PM
99'explorer
Nov 29, 2006 06:58 PM
wavinwayne
Mar 15, 2005 10:49 AM
