Sponsored by: Real Truck
Dumb question maybe.....
Old Mar 6, 2018 | 02:54 PM
shanekw1's Avatar
shanekw1
Red face Dumb question maybe.....
But please humor me. What is this doo dad attached to my hood with the wires cut?
Old Mar 6, 2018 | 03:12 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Something the factory didn't put there. Looks like some wires are connected to the pass-thru wires, what fancy junk is installed inside the cab?
Old Mar 6, 2018 | 03:31 PM
Chuck's First Ford's Avatar
Chuck's First Ford
mercury switch for an alarm system????? open hood and alarm will sound.
Old Mar 6, 2018 | 03:39 PM
shanekw1's Avatar
shanekw1
The pic is hard to see but it has 2 black wires coming out of it and they are both cut off.
Old Mar 6, 2018 | 03:41 PM
shanekw1's Avatar
shanekw1
I haven't found anything alarmish looking, but it does have an OEM remote starter, is it possibly a hood switch for that?
Old Mar 6, 2018 | 03:51 PM
texastech_diesel
Token Redneck
Yes the piece on the hood is cut off, but there are two wires lower hooked to the pass-throughs. If it were something like an alarm the cut off the wire off the bracket that might have been a sensor wire that went through the firewall instead of being spliced, but those two wires other could end in a pigtail in the cab off the pass-throughs that match a power connector to something. If one thing is weird, look at ALL the weird stuff to try to gleen a better picture.
Old Mar 6, 2018 | 03:54 PM
Sparky83's Avatar
Sparky83
i agree with the others... most likely the merc switch for an alarm since the 2 running next to it are the wires for the underhood light...
Old Mar 6, 2018 | 04:19 PM
shanekw1's Avatar
shanekw1
OK, you made me go look again. The 2 wires for the sensor are cut off, with nothing around looking like something they should be attached to, the four? pass through wires have nothing connected to them, and the 2 doing a small loop under the harness are connected to the firewall under a screw.
Also, under the dash were 2 random wires coming from the remote start module, a purple with white stripe and a grey. The purple is for the tach signal (or so I've read) and the grey is for the hood sensor (so I read), which, aside from this weird doo dad, I see no evidence of.
Old Mar 6, 2018 | 04:54 PM
geekwithoutacause's Avatar
geekwithoutacause
NSA listening device. They're on to you.
Old Mar 6, 2018 | 04:55 PM
shanekw1's Avatar
shanekw1
I knew it! That also explains the mysterious black Suburban.
Old Mar 12, 2018 | 11:46 PM
shanekw1's Avatar
shanekw1
I have determined that this is a hood switch for the remote start, and that the mysterious 2 wires under the dash were for this, and the tach wire which was spliced into an injector wire.
The remote start still doesn't work, but that's another story.
rustyshakelford
Nov 29, 2016 03:28 AM
Number21
Nov 3, 2013 11:01 AM
Alan17
Oct 13, 2013 04:51 PM
Liquid10Rider
Nov 20, 2011 12:43 PM
hedhntr
13
Jul 22, 2010 12:49 AM
