Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
5 speed swap
Old Mar 5, 2018 | 10:09 PM
Timber cutter's Avatar
Timber cutter
5 speed swap
Will a 5speed transmission out of a f800 7.8 motor bolt up to 6.6 in a f700?
Old Mar 5, 2018 | 11:04 PM
85e150's Avatar
85e150
Welcome to FTE!
Usually transmissions in that size truck will swap in later model trucks with SAE bell housings.
What years and what transmission and what engines are we talking about?
Old Mar 8, 2018 | 10:40 AM
92exp4x4's Avatar
92exp4x4
I'm not certain of years/ vehicles, but chances are really good that if the trans case is round, it's an SAE bolt pattern. This is a standard that most equipment and anything built with a Cummins or many Allison transmissions use. I think the newer Ford diesels are now using this pattern, but I haven't measured one.
I know a guy that bolted a 4BT Cummins into a 1936 Farmall F-20. It's an amazing machine and spins our sawmill like a champ!
If you have a vehicle you're wanting to make a swap into, there was an adapter Ford made to mate their engines to a "Transmatic Drive" 6 speed auto starting in 1957. It's an early Allison transmission and uses the SAE pattern. I would say you may find this adapter for any of the engines Ford offered in these heavier trucks over the years to convert it to this pattern.
46duke
24
Nov 19, 2016 10:26 AM
juchertf100
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 24, 2015 12:05 PM
postmaster ford
4 Cylinder Engines
May 24, 2012 12:04 PM
regulator
Mar 1, 2012 02:43 PM
AndysFords
General Diesel Discussion
Jun 23, 2006 06:23 PM
