97 Powerstroke gearing
Old Mar 5, 2018 | 09:23 AM
redkw's Avatar
redkw
I have a 97 cclb 2wd dually I'm daily driving and I'm wanting lower rpms at 70 currently running around 2600rpms. I assume its a 4.10 and i have 29 inch tires. what should I do?
Old Mar 5, 2018 | 01:23 PM
Briansshop's Avatar
Briansshop
A gear change to 3.55s would drop that to about 2150rpms. Not a cheap thing to do if you have to pay a Mech to do. I don't rem if you could get 3.55s in a DRW from Ford. If so, scoring a complete axle from the junkyard would be less $$.
Old Mar 5, 2018 | 01:46 PM
Ddaybc's Avatar
Ddaybc
You could also go to a 31 or 33 inch tire. However swapping six tires may end up costing you as much as re gearing. Offhand I don't know what the change in rpm would be if going from the stock tire size to the larger size. Now that I think of it, my F250 comes standard with 235 85 R16 and they are 31's. I thought the duallies came with the same? What size are your tires? The stock F150 tires are 29's and I think they were 245 75 R15 but don't quote me on that.
Old Mar 5, 2018 | 01:51 PM
redkw's Avatar
redkw
i have 225/75/r16
Old Mar 5, 2018 | 02:14 PM
FordTruckfan89's Avatar
FordTruckfan89
3.55 gearing may prove to make it a bit laggy pulling much. 235/85r16 would definitely help. Should be 60mph at a little over 2000 rpm.
Old Mar 5, 2018 | 02:15 PM
FordTruckfan89
Get the axle code off the door, or off the rear axle cover.
Old Mar 6, 2018 | 08:03 AM
redkw's Avatar
redkw
Well the doors were replaced so i do not have that info plate. Otherwise i can check my diff cover around 3 today
Old Mar 7, 2018 | 09:39 AM
Diesel_Brad's Avatar
Diesel_Brad
Just a FYI. your current 4.10s or 3.55s will net the same milage. Just the 4.10s will have more power
Old Mar 7, 2018 | 10:19 AM
redkw's Avatar
redkw
how will it net the same mileage if the rpms are lower at higher speed? Less fuel is being used
Old Mar 7, 2018 | 10:40 AM
Ddaybc's Avatar
Ddaybc
What is your rpm at 60? My truck has the ZF5 and at 100 km (62 mph) in 5th my rpm is 1900. I have never taken it up to 70 so I have no idea how much the rpm would change. However, comparing your truck with your tires to my truck with stock tires may give you an idea about gear changes or tire changes?
Old Mar 7, 2018 | 11:46 AM
Briansshop's Avatar
Briansshop
Has to do with keeping the engine at an rpm where it's making peak torque and requires minimum throttle. At a lower rpm where less torque is made, more throttle will be required to maintain the same speed. There are a lot of variables here, but that the basics of it.
Old Mar 7, 2018 | 01:47 PM
redkw's Avatar
redkw
its 2000 rpms at 55
Old Mar 7, 2018 | 02:00 PM
00t444e's Avatar
00t444e
A stock 7.3 has a torque peak at around 1600-2000 rpm so staying around that rpm would give you the best fuel mileage. 3.55 gears would help or you can put 35s on the rear.
Old Mar 7, 2018 | 02:05 PM
redkw's Avatar
redkw
Yeah im not about to have 35s on the rear and 29s on the front. My fathers 7.3 has 33s and it does way better than my truck. His is a 97 f350 cclb 4x4 srw same engine trans and rear end i believe
Old Mar 7, 2018 | 03:01 PM
Diesel_Brad
And 2 less tires of rotational mass and less wind drag.
