Sponsored by: Real Truck
brake replacement issues
Old Mar 3, 2018 | 06:38 PM
Demoman85's Avatar
Demoman85
hey y'all I have a 2000 super duty and I just replaced the front rotors but the seem to rub on the bracket has any one else had this issue and how did you fix it
Old Mar 3, 2018 | 07:13 PM
Chuck's First Ford's Avatar
Chuck's First Ford
first check if you got the wrong rotors... then is the rotor sitting flat and true on the hub..!!
I am assuming you have a 4x4 ???????? you do not say...
Old Mar 3, 2018 | 08:02 PM
99f350sd's Avatar
99f350sd
If its a 4x4 you might have early 99 rotors..unless it has an early 99 front axle..OR someone put early 99 bearings on it.. If a 2wd I have no idea.
Rattler05.5
Feb 14, 2014 12:33 PM
KRAZY KRAMER
Sep 9, 2011 02:01 AM
Brad99SD
Dec 1, 2008 07:24 PM
