Cab Cart?
Old Mar 3, 2018 | 05:50 PM
Dano61's Avatar
Dano61
Smile Cab Cart?
As I am new to this whole truck restoration process, I now have the cab ready to be removed. I am looking for a simple diagram or spec sheet on how to build a good cart to place the cab on so I can move it in and out of my one-man shop. Any suggestions?
Old Mar 3, 2018 | 08:16 PM
resonateur's Avatar
resonateur
I used a portion of a frame from a parts truck, but unlikely you would have the same situation. Just use 2x4's, casters and a bunch of screws. Bolt holes will line up with your cab mount points.
Old Mar 3, 2018 | 11:58 PM
JefflovesF250s's Avatar
JefflovesF250s
Cab cart
I used 2x4’s on edge screwed to 2x6’s on the flat. The 2x4’s fit in the channel that runs under the doors and are the length of the cab.
Join the 2x4/2x6 T sections with 2x6’s also on the flat and running across the front & rear of the cab and this gives you the base to attach casters, with built in plates.
Old Mar 4, 2018 | 04:09 AM
Crop Duster's Avatar
Crop Duster
Cab
I used some scrap wood and some cheap 8 inch caster wheels from Harbor freight. I don't have a hard surface out doors and the bigger wheels roll a lot easier in the gravel. Right now the same contraption is holding my bed up.
Old Mar 4, 2018 | 06:19 AM
User 71024's Avatar
User 71024
I just bought a rotisserie so I'll be using that this time around, but when I was doing my mustangs I bought a single section of the HD adjustable pallet shelving and bolted body mount brackets to it. worked great cause you could make it any height you wanted for the work you were doing at the time. Just add some large casters and your good to go.
jniolon
17
Jan 15, 2022 08:15 AM
4EyedTurd
17
Mar 19, 2019 07:16 PM
sum_weirdo
Aug 18, 2016 08:13 PM
grinnergetter
Jul 21, 2010 04:54 PM
Lwlandy
Oct 6, 2005 09:24 AM
