Cutting off after accelerating
Old Mar 3, 2018 | 02:15 AM
Jason185512's Avatar
Jason185512
I have a 1994 Ford F150 with 5.8. It idles perfect when not moving but whenever I accelerate and let off to come to a stop, it idles low and cuts off. Anyone have any idea what might cause this? Thanks.
Old Mar 3, 2018 | 02:28 PM
'89F2urd's Avatar
'89F2urd
need more info. what trans? pull codes?
Old Mar 3, 2018 | 02:32 PM
Jason185512
E4OD. No codes or CEL. Vacuum 21 at idle.
Old Mar 3, 2018 | 03:10 PM
'89F2urd's Avatar
'89F2urd
Have you checked the iac to see if it's sticking?
Old Mar 3, 2018 | 03:13 PM
Jason185512
No I have not. Be a good place to start.
Old Mar 8, 2018 | 10:50 PM
Jason185512
Cleaned IAC and checked resistance/voltage and problem is still occurring. Also checked transmission filter to see if it fell out and it had not, but I replaced it anyway along with fresh fluid.
Didn't mention I did an EGR delete because I didn't think that would have anything to do with it but it could for all I know. I vacuum capped everything, plugged the heads, and soldered resistors to all of the different solenoids. No codes or CELs.
Like I said before, even after the EGR delete, vacuum is steady at 21, idle is steady around 900. Maybe next place to check is TPS???
Old Mar 9, 2018 | 08:33 AM
rla2005's Avatar
rla2005
Even though you cleaned the IAC it can still be the cause of your issue. But before throwing parts at it verify the TPS output is within specification at closed throttle and increases smoothly when opening to WOT. Watch for any dips or spikes.
Old Mar 9, 2018 | 04:05 PM
Jason185512
TPS checks out perfect. Worst part of all of this is that it only happens occasionally...
Huntot7
Aug 2, 2017 07:58 PM
stephen.osborne1
Mar 26, 2015 10:23 AM
GWTarpon
Feb 5, 2004 11:27 AM
Todd Varvel
1997 - 2003 F150
Sep 26, 2003 09:25 AM
