trans mount
Old Mar 2, 2018 | 01:01 PM
BuddyBarnes's Avatar
BuddyBarnes
trans mount
Any one know the part # for the 94 zf5 trans mount? Seems they had two one 59 mm bolt holes and one 69mm bolt holes. Ford said 59mm is obsolete.
Old Mar 3, 2018 | 08:11 AM
Talyn's Avatar
Talyn
Are you looking for the cross member, or the piece that goes between the trans and the cross member? (guessing the latter)
As far as I know, there is only 1 size for all ZF5's.
The other size is probably for E4OD.
Old Mar 3, 2018 | 09:13 AM
BuddyBarnes
The latter . The rubber mount. Per ford there are two , one 59mm and one 69 mm. I always thought there was only one.I have also looked at some order sights and they state the same. I will get under the truck and get a measure later. I think it is 69 mm. Some parts houses say the auto and manual take the same mount. IDK. When I called ford I thought this will be simple,it is just a trans mount. LOL.
Old Mar 3, 2018 | 10:02 AM
97-psd's Avatar
97-psd
At least your luck seems better than mine. Mine would’ve had the 59mm
Old Mar 3, 2018 | 11:49 AM
BuddyBarnes
Mine may be. lol I dont know yet
Old Mar 3, 2018 | 05:17 PM
Talyn's Avatar
Talyn
I'ma bet the smaller one is for the ... crap, uhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
Come on brain.
m5od.
There we go.
And the larger is for the zf5.
Old Mar 3, 2018 | 06:11 PM
BuddyBarnes
Come on brain.
m5od.
There we go.
You may be correct.
ftlover90
13
Apr 17, 2017 06:33 PM
gtrosema
May 16, 2012 02:25 AM
Jake59lighting
Sep 5, 2009 12:34 AM
psquare7575
Dec 1, 2007 08:26 PM
