ignition wire diagram
Hello all,
I need to find what wire energizes the coil while cranking. I had an old chevy before that put juice to the coil while cranking on one circuit and then a different circuit while running.
When starting my truck, it feels like it will not fire while in the start position and once i let the key back to run the thing will start. Like no spark while cranking. Before i climb up into the thing, can someone guide me where to start looking.
Thanks,
Chris
Anyway, on your starter solenoid, the RED/b wire goes to the 'S' terminal and closes the contacts such that the starter is engaged. Since the starter runs this wire is fine. The 'I' terminal has a BROWN wire and its job is to provide BATT voltage in START to the coil...once started, its job is done and no VDC should be realized there. The ballast resistor circuit takes over and ~ 8VDC is supplied to the coil......Not unlike your old Chubby, as well as a plethora of other vehicles.
You don't have a wiring problem here...there's something gone south with the primary starting circuit or there's some dirty connections in the same area.
Question: When you let off the key to RUN, does she stay running or poop out?
Since yours is only firing up when you let off the key, it sounds like you might have more than one issue at a time to deal with.
One would be a failing ignition switch (no power to the ignition in START) that is only sending power up the line in RUN.
The next would be a failing starter relay/solenoid that no longer sends power out through the Brown wire.
I'm not sure if anything going wrong with the ignition control module (ICM/Duraspark box) could mimic those symptoms, but they do go bad and if there is something there that could be causing it, it would be hard to see and test for without simply replacing the module.
I hate throwing parts at a problem (but have done it many times anyway!) but I'm not sure how to test a module other than to put it on another vehicle with the same connectors to see if it works there.
A failing radio noise suppressor/capacitor/condenser/thingy can cause a no-start issue when it short circuits to ground through it's case, but that will keep it from running at all. Not just in START.
Good luck. Probably more things than I can think of at the moment, so maybe someone will chime in with the cure.
Paul
Before giving a "possible" component failure scenario, I like to have questions answered...and then on to troubleshoot one symptom at a time. I'm simple like that. And the OP hasn't answered one question. Mebbe he figured it out already.
Before fixing a broke whatchamuhcallit one has to know how or what caused it to break. Otherwise, one is reduced to throwing parts at the booger-man in hopes something scares him away.
If so, please answer the question I posted earlier (post #2) as there are some simple troubleshooting tests to determine to root cause of this illness........that is, of course, if you want our help. If you have other ideas and want to go it alone, well, good luck.
I will post what i find in a few days,
Thanks for all of the info,
Chris
