86 Pitman arm options
Old Mar 2, 2018 | 08:30 AM
Blackduck59's Avatar
Blackduck59
Have a 350DRW , where there any length difference in pitman arms on these?
The one I have is 5.5" from sector shaft to the ball joint center.
Found a few threads about drop/offset ones but nothing on distance between centers.
Would like a longer one if possible.
Cheers Steve
Old Mar 2, 2018 | 08:48 AM
FuzzFace2's Avatar
FuzzFace2
I got to ask ...... Why you need a longer one?
I would think be it stock or dropped the C to C will be the same the drop one just puts the rod back where it should be with out a lift.
Dave ----
Old Mar 2, 2018 | 09:28 AM
Franklin2's Avatar
Franklin2
Sounds like he wants quicker steering. But that would be harder on the steering box and harder on the frame also where the box mounts. And we know frame cracking is a problem on these trucks. He has a large truck with probably large tires, he should think about it before trying to find a longer pitman arm(if they made one).
Old Mar 2, 2018 | 11:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1986 F350 with DRW (Dual Rear Wheels)
Note: The OP lives in Australia, the following Pitman Arms are related to the US/Canada.
These probably won't be correct, since Aussie trucks have RHD and they drive on the "wrong side" of the road.
E2TZ-3590-C .. Pitman Arm-Use with Power Steering = 1980/86 F100/350 2WD & 1980/89 F150 4WD & Bronco.
E3TZ-3590-G .. Pitman Arm-Use with Manual Steering = 1983 F250/350 2WD from production date 3/83 & 1984/89 F250/350 2WD
E5TZ-3590-A .. Pitman Arm (marked: E5TA-3590-CA) = 1985 F350 4WD from production date 2/85 & 1986/89 F350 4WD
Old Mar 2, 2018 | 06:13 PM
Blackduck59
Just asking if there were differences. Have a very poor turning circle and looking to improve it.
There is plenty of clearance to chassis and body parts for a little more lock to lock.
Correct about the right hand drive and this is an Aussie steering box so the USA splines maybe different.. Like an idiot I gave away the LHD box during the conversion and I have a feeling the arm was longer on that box. Still trying to track it down as the place it went to had a fire and damaged a lot of stock.
As I doubt many F350's were assembled here my guess is they used F100/150 parts.
Standard tyres and rims
Would still like a measurement center to center if someone can help out
Thanks for your thoughts and concerns
Cheers Steve
Old Mar 2, 2018 | 06:23 PM
FuzzFace2's Avatar
FuzzFace2
When I get back out to my garage tomorrow I can measure the one on my F100.
I will also check where the steering stops are, out at the spindles or in the box?
Dave ----
Old Mar 3, 2018 | 12:10 AM
Blackduck59
Dave,
Thanks.
My stops are in the axle ends, work on the spindles.
This truck is Canadian build, ex USA. Current box is ex Aus F series. Just what it came off is a good question. A Kirby Bishop box if I have it right.
Could call it an "International Bitza" as there are so many parts from different manufacturers that have gone into the build.
Old Mar 3, 2018 | 07:21 AM
Franklin2's Avatar
Franklin2
Just for your info, the steering boxes on f150 thru f350's are all the same over here in the states. It's the same box as used on the little ranger pickups over here also. If you ever need a used steering box from the junkyard, it's best to get one from a ranger pickup, it leads a easy life guiding the little pickup around.
Don't know about Aust interchange though.
Old Mar 6, 2018 | 10:05 PM
Blackduck59
Thanks for the heads up on the Rangers but don't think Ford bought the USA versions in here, mostly badge engineered Mazda's and Nissans
Would still like the measurements if someone has a chance to do some measuring.
Cheers Steve
Old Mar 21, 2018 | 07:04 PM
Blackduck59
Bump.
Would still appreciate if someone can measure their pitman arm, center to center. Would like to see if they are the same as the Aussie arms.
Thanks Steve
lauxg
Apr 14, 2018 01:35 PM
bigcrunch
May 6, 2017 04:28 PM
Inline66
WTB - Parts & other
Nov 10, 2016 02:20 PM
blacktundra10
Dec 27, 2011 08:49 PM
dogguira
Jan 21, 2009 02:32 PM
