1 inch rear lift to level my truck from a front level kit
#31
#32
yeah, I have lift spacers on my Firestone air bags to accommodate the lift that’s on my Dodge so the first thing I did is call Air Lift, which I have on my Super Duty, and they offer nothing to accommodate any sort of lift. Their bottom bracket uses the curvature of the factory bump stop tang and this is why I opted to just use the simple one inch blocks under the factory blocks. This way I won’t have to modify the Air Lift system other than replacing their 10 inch carriage bolts with 12 inch ones and then cut them to fit. Thanks for the suggestion.
#33
Daystar? - Driven by Design
#34
Summit Racing has some spacers that are supposedly from AirLift and look to be the same diameter as the bags and just bolt up to the bottom of the bags. They come in 2"-4" and I want to say 6" kits but the spacers are just 1" blocks.
Stacking blocks is not the greatest thing, in fact it's pretty bad honestly. I would be looking at something different if it was me.
#35
You need Daystar Cradles, they do exactly what you are looking for. Stacking blocks is a really bad idea.
Also, Rough Country does exactly what I want to do too for their 08 F150 level kit. They add a 1 inch spacer block to stack with the factory block if the customer wants to maintain a bit of rake.
Hear are the links. What do you think? I'd never would try and stack two, let's say, 3 inch blocks together but would there actually be that much force on a 1 inch solid spacer block below a 3 inch factory block. I'll probably abort what I want to do but it really seams like my only option to maintain good ride quality and lift only 1 inch with my current air bag system that has jounce bumpers inside of them (they are like bump stops). The positioning of these bags is critical as not to constantly hit those jounce bumpers.
Here are the links I was talking about. I'd like to hear your feedback. Thanks
2.5in Leveling Lift Kit for 04-08 Ford F-150 Pickup Rough Country Suspension Systems®
#36
The reason you don't is two fold, larger blocks increase axle wrap and you need longer ubolts to hold the assembly. Longer ubolts tend to stretch more which means the coupling between the blocks is now looser and you're also applying more force there. It's a compounding issue.
Now, what's the likelyhood? I couldn't tell you, but it seems like you actually off-road your truck and do you really want to be 60 miles out in the bush when you collapse a block? If you're street-queening your truck, then sure, probably won't be an issue other than the increased axle wrap.
Here's a quick blurb from 4 Wheel Parts:
https://www.4wheelparts.com/buyers-guide-reviews/lift-kit-how-to-leaf-springs.aspx
So, where does that leave you?
I think the Daystar cradles are your best bet, but I'm not sure with your jounce bumpers. They seem to be there most popular with guys that are doing exactly what you're doing. You can also look at long travel bags, but those are more money and you're replacing parts you've already bought, which sucks.
You could do a rear shackle with a larger bump maybe? Or an add a leaf? I'm not sure without understanding your exact setup and the measurements of the components, etc.
OneOne thing to keep an eye on with regards to lift blocks are the u-bolts. Longer ones tend to stretch and loosen up, so you should regularly retorque them for safety. That’s one reason why you never, ever stack lift blocks because they can collapse more easily if the u-bolts become even slightly loose. Most of the time, you can combine blocks with lifted leaf springs but you should never install blocks up front. You might survive a rear lift block collapse but, since the steering is up front, it makes for a more critical situation if it happens there.
#38
#39
I too am bugged when I hook on my 12k lb tongue pull. With only 1" extra in the back it wasn't enough. So I added 2". They have bump stop pads too.
Jack-it.com out of Utah. 150 bucks incl u bolts.
I ran stock shocks for a month. They worked fine but I added Bilteins. Now it rides like a German car.
#41
I’m figuring I have over 600 pounds between my shell, camper kit and all of the gear that stays in the truck all of the time so I have definitely lost some height back there. Those damn jounce bumpers don’t give you chit for travel before they engage. My tongue weight must be pretty darn heavy because it really does take a lot of air to level it out. I get the best ride at around 45 pounds and that’s about 45 pounds short of leveling it. I really like those PMF blocks. I’m going to give them a call tomorrow and see it they’ll fab some blocks to my specs. After removing my bags and taking a close look at them I figured I can bolt them directly to the PMF blocks with air bag supports and get rid of a lot of brackets and bolts. I do appreciate your feedback and like you, I don’t want to worry about chit like that. Yes, I’m on some pretty rough roads but it’s always at a turtles pace compared to you desert racers!
#42
So you want an unlevel kit for your level kit? Sorry had to. I want the exact same thing. Level kit looks great but add any weight and you have the horrid cali lean (rear end sag).
For this reason I plan to use the carli (deavers) full rear leaf pack with provides a 1" rake in the rear over the front 2.5" lift.
#44
Check out Atlas Spring here in CA, they do a boat load of race trucks, but they also make commercial springs and aftermarket truck springs. Take a look at their Expedition models. They are supposedly a better street ride as well as specifically designed for towing and payload. I think that's eventually the way I'll go myself, just can't give up that payload, but I know you can do better than the oem ride.
#45
