1 inch rear lift to level my truck from a front level kit
I am also trying to figure out lift vs level. I have 20” aftermarket rims with 35” tires waiting to go on. I plan on using the ready lift 2.5” front springs and the metal fab’s rear blocks (thanks Tricon). My truck has a 2” rake from the factory. Anyone know what the taper should be on a 5” (+2” over stock) block should be? It’s 2.5* or 5* or 0...
Thanks man. That is the kit number I'm trying to verify with Ready Lift.
I'm hoping someone will chime in who has actually installed these. I also have airbags that mount on the bumpstop tangs so I'm also trying to verify that the bump stop tangs on the Ready Lift are similar to the factory tangs.
I swore I wouldn't lift my next truck and just level it. I suppose a one inch lift doesn't count as a lifted truck, haha. I dropped a fortune on my Fox resi adjuster shocks so a four inch lift is not in my future anytime soon.
K-tung, thanks for the photo, that helps out a lot!
Tricon, thanks for the tip on the metal fab blocks. I really like the way the blocks will be locked in and can’t shift. Since I have the Transfer Flow 60 gallon tank on order I could order one block a little taller to compensate for any side lean from a full tank of fuel. I really wish you didn’t tell me those shocks can be rebuilt with longer shafts. I have an old blown non adjustable Fox resi I can practice on first.
Great options, thanks
I did this a couple weeks back and so far I'm pretty happy with it.
Readylift 2.5 front level
Readylift 4" rear block 66-2024
295/65/20 Nitto Ridge Grapplers
I didn't realize until after the install but the factory 3" blocks are tapered and meaure around 3 3/8" on the rear side and the readylift blocks measure exactly 4", so the end result is only about 5/8" rear lift. I'll probably leave mine as it is, but if I was doing it again I may consider the 5" blocks.
Jr.Parrish, Where the Readylift blocks tapered at all like the factory blocks? I would imagine that they would have to be to achieve the proper pinion angle.
Thanks
Thanks
Thanks
Thanks
It just drives me nuts when I have the "Cali lean" when I'm towing. (no offense to Tricon)
Since the blocks are tapered the actual lift height should be measured at the center pin. I have my stock blocks sitting on the floor in the garage and can measure them up, I want to say I measured 3 1/4" on the large side and 3" or maybe 3 1/16" on the short side. Meaning the stock blocks might be 3 1/8" technically. The 4" block may? measure over 4" on the tall side making them a true 4" tall block at the center (this would be my assumption)
I guess where I'm headed there is that I don't think you're going to be able to reuse the stock U-bolts.
This is interesting. I just received this from Readylift. It appears the 66-2024 are not correct.
I’m sorry Robert, I should have addressed your other questions as well. You are correct on the lift height, if you have a 3 3/8 factory block and you replace it with the 4” block, you will net 5/8” of lift. The part number you provided will not work on your 2017 truck, I will include part numbers for the appropriate blocks below.
66-2740 – 4” Block for 1 piece driveshaft
66-2741 – 4” Block for 2 piece driveshaft
66-2750 – 5” Block for 1 piece driveshaft
66-2751 – 5” Block for 2 piece driveshaft
66-2760 – 6” Block for 1 piece driveshaft
66-2761 – 6” Block for 2 piece driveshaft
#28
#29
I guess they're not cast iron for the 17's and up. They are very similar to the PMF blocks that Tricon posted.
https://www.readylift.com/4-0-tall-t...uper-duty.html
#30
I didn’t order the blocks from Readylift because they said that they are not rated for air bags that mount on the blocks bumpstop tangs like I have on my truck. I liked the blocks from PMF like Tricon suggested but it would have required too much fabrication to my existing air bags to make it work.
i ended up ordering some 1 inch blocks from Moto Fab and some new U bolts from PMF. I’ve read that stacking blocks is not a good idea but I don’t think adding only 1 inch blocks will be a problem. I was disappointed that the U bolts from PMF were raw grade 8 steel. They are going to rust quickly so I’ll shoot them with some paint. I took off my airbags and my dealer is going to put the new blocks and U bolts on this Wednesday when my truck goes in for my new 60 gallon Tranfer Flow fuel tank.
No more sagging while I am towing!
