Will I have rubbing issues?
Old Mar 1, 2018 | 06:57 AM
dananash2000's Avatar
dananash2000
I plan to install bds 2" leveling kit with fox shocks soon, but my question is will I be able to fit a 325/50r22 tire on 22x10 -25 offset wheels without it rubbing? I do have bushwacker pocket flares on it now, will they rub on the flares as well? I also have the plow prep coils on my 2018 f250 as well....if that would help. Let me know what you guys think....thanks!
Old Mar 1, 2018 | 08:39 AM
Roly Poly's Avatar
Roly Poly
Have you tried the tire offset calculator, it will show where your original tire is vs your new tire wheel combo... If the new tire is moved in, then there is good chance it will rub. Let us know...
https://tiresize.com/wheel-offset-calculator/
Roly
Old Mar 1, 2018 | 08:55 AM
C_Smitty's Avatar
C_Smitty
If you want to make sure you won't have rubbing issues, then you should do what the manufacture suggests to do.
BDS suggests to use the following combinations for their 2 inch kit:
  • Tire & Wheel Combinations
  • 35" x 12.50" w/17 x 9 and 4.5" back spacing
  • 35" x 12.50" w/18 x 9 and 4.5" back spacing
  • 35" x 12.50" w/20 x 9 and 4.5" back spacing
Old Mar 1, 2018 | 09:00 AM
h20camper's Avatar
h20camper
Originally Posted by Roly Poly
Nice!
Old Mar 1, 2018 | 10:48 AM
CBEllis's Avatar
CBEllis
^^^This^^^
That 325/50 is a FAT tire (and it weighs a ton).
I’m afraid you may have issues for-sure with only a 2” level.
Old Mar 3, 2018 | 07:04 AM
dananash2000
The 325/50r22's only measure out to be about a half of an inch wider so I wouldn't think they would make much of a difference over a 12.50 wide tire
Zamarrda
Mar 18, 2019 08:08 PM
$Chip$
Mar 6, 2019 10:43 PM
tractorboy924
2009 - 2014 F150
Oct 28, 2018 09:12 AM
ruger761
Aug 11, 2012 03:06 AM
edjunior
May 1, 2009 05:20 PM
