95f150 302
Old Feb 28, 2018 | 06:39 PM
Ethan24's Avatar
Ethan24
95f150 302
Will a efi 302 out of a 91 lincoln town car fit in my 95 f150
Old Feb 28, 2018 | 07:53 PM
Mudsport96's Avatar
Mudsport96
Yes. It has a smaller camshaft, and possibly the e6se heads giving it lower compression.
It will bolt in and work, but will be down on power.
What is wrong with the current engine?
Old Feb 28, 2018 | 08:03 PM
Ethan24's Avatar
Ethan24
When i bought it 2 weeks ago the guy said it would not start, got it home and got it started last weekend. Was missing real bad amd it made a pop sound and started smoking pretty bad, thanking freeze plugs. Also was getting some blow by.
Old Mar 1, 2018 | 01:31 AM
TexasGuy001's Avatar
TexasGuy001
The earlier town car motor should work fine, but like was mentioned will likely make less power. Unless it is leaking antifreeze I doubt I would suspect freeze plugs. I would read the codes and check fuel pressure and for vacuum leaks.
Old Mar 1, 2018 | 08:30 AM
Conanski's Avatar
Conanski
Is your '95 truck MAF? If so the Car engine is not directly swappable as it will have the wrong firing order and that has to match for sequential injection. I think you should do a little more troubleshooting on the truck before writing off the engine.
Old Mar 3, 2018 | 09:24 PM
stak's Avatar
stak
if your truck is MAF (mass air flow) 5.0 HO and it should be. the only car 5.0 that will work are from an 85 - 95 Mustang or 86 - 92 Lincoln Mark VII and if you can find one the 85 / 86 small LTD LX. however you should also look at a 5.0 HO V8 Explorer / Mercury Mountaineer. they will have cast iron GT40 heads. The Lincoln Town car / Crown Vic / Grand Marquis / Thunderbird / Cougar and so on only had 5.0 EFI this engine will work in the F150 if it does not have mass air flow.
Cowboy34
Aug 13, 2010 09:14 PM
muddplay
Offroad & 4x4
29
Oct 31, 2008 05:37 PM
4x2mudder
13
Mar 29, 2008 07:23 PM
jasontio2469
Apr 12, 2006 09:53 AM
Greg McElroy
Nov 2, 1999 11:16 AM
