Third brake light/cargo light sockets
Old Feb 27, 2018 | 08:51 PM
walmill's Avatar
walmill
Hello all my third brake light socket is burnt out the connector is loose the cargo light sockets are a bit brown theyre a little Loose as well.
I took it to a guy that does a lot of custom studf he said he didn't really know what to do with it. His suggestion was to file the connectors inside get rid of any corrosion and then sueeze the sockets with needle-nose pliers to tighten the connection.
Ideally I would find a complete replacement wire harness for an affordable price but haven't been able to. I don't even know if anyone even carries anyat all so I've been looking at sockets I can't find any direct matches. local parts stores don't have any that would match. I figure I could jerryrig something but I'm kind of thrown off by one of the cargo sockets connecting through to the other. Does anybody know and can link to me sockets that would fit, or a new harness I really don't want to upgrade to an LED kit I think they look gross and I just gave my light assembly a facelift and it looks brand new.
Old Feb 28, 2018 | 12:40 AM
TexasGuy001's Avatar
TexasGuy001
I would replace the connectors by soldering in and heat shrinking new ones. It is typical of these lamps to melt housings and sockets. There should be a socket at most stores that could be used. I never actually looked though. I suppose they might be too small.
It's looking more and more like these lights are biting the dust. I am currently working on an idea to create an LED panel and LED bulbs for the cargo lights, to repair a melted unit, but I've not found anything that I'm happy with the result of yet. See this thread.
https://www.ford-trucks.com/forums/1...ake-light.html
Old Feb 28, 2018 | 01:53 PM
Binkowski's Avatar
Binkowski
I always look in Bronco Graveyard for this type of thing. I don't recall the year you said, but here's a couple:
https://shop.broncograveyard.com/09-...ctinfo/649595/ Looks just like my '95.
https://shop.broncograveyard.com/198...uctinfo/34995/ but does not appear to have the light assembly. Search around. Good luck.
Old Feb 28, 2018 | 02:37 PM
walmill's Avatar
walmill
I don't get why one isn't readily available given how common this problem seems. You can find every random connector but not that. On my day off I will take my lens and light and walk every parts store something is bound to be able to work.
unfortunately I need the light wiring/sockets. My lens looks brand new after some fine sanding and clearcoat
Old Mar 1, 2018 | 12:23 AM
TexasGuy001
Old Mar 1, 2018 | 12:24 AM
TexasGuy001
The factory bulb sockets are some of the cheesiest I think I've ever seen. I found some similar at Oreilly and Advance, but they are for 194 bulbs.
SVTDriver97
23
Dec 19, 2014 07:16 PM
Wizness
6.7L Power Stroke Diesel
Dec 18, 2013 09:12 PM
RabidJade
General Automotive Discussion
Jun 30, 2013 09:43 PM
CalebJns
Mar 8, 2012 08:05 PM
BlakePopovich
Jul 25, 2011 10:00 AM
