390 Oil Pan??
I have a 2wd F250 390/C-6. It has a front sump 2wd truck) am assuming as it is not off yet and the new one has not arrived to compare them. Mine is in fine shape, but since I am redoing the motor I am also getting pretty much everything new or rebuilt and am stepping up a notch on most things. Thought I would just get another new paw, especially since they were cheap and available in zinc or chrome. Or so I thought, till I start finding out that a new truck pan is harder to find and more expensive, than just having my old one refinished(I still may do this if I am not satisfied with the new one. I have not pulled the motor yet, although it just needs to be massaged from the trans. I did not have an extra stand to use. So I picked up a HD used one today for a C Note. I am think with the cost of a new pan if available, as my pan is probably peppered under the last spray bomb. I may have it T'ed like a Cobra pan except with the measurement taken today and the below pics it would either have to be no more than 9" across the front and no more than an extra.5" lower at the bottom (or it will hit the crossmember) , It could be 12" across but the T would have to be offset to the drivers side by a up to 3".
'nilla60
15
11-18-2009 11:06 AM
MacOffutt
07-24-2005 03:09 PM
DJ Rosa
02-29-2004 07:33 AM
1QUICK75
01-10-2002 11:56 PM
