6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Navigation
Old Feb 26, 2018 | 04:50 PM
Christiansl's Avatar
Christiansl
Navigation
will a oem navigation system from a 2015 expedition work in a 2008 F350?
Old Feb 27, 2018 | 06:13 AM
Firefighter 1406's Avatar
Firefighter 1406
From what I have read the plugs on the back of the radios change frequently. I have been looking for one in my 09 and they are too expense to take a chance and I haven’t found a 100% answer yet. Pass it on if you find out anything.
Old Feb 27, 2018 | 06:51 AM
73F700's Avatar
73F700
I don't believe it is a straight swap. I have an 2008 with the 6 disc and was going to put a 2012 with nav in it however the 6 disc has an internal amplifier and the nav unit uses an external amplifier that is mounted somewhere under the steering wheel.
If your 2008 has Nav then its possible that it already has the external amp and you might be good to go. if not then there would be a lot of custom work involved..
Old Feb 27, 2018 | 09:32 PM
Firefighter 1406
There is a company that sells everything needed for the swap but it was $1600 if I remember correctly. Bought my nice Garmin for $100.
Old Feb 28, 2018 | 04:59 PM
sxrfun's Avatar
sxrfun
I also think you have to egt the ACM (accessory control module) flashed at the dealer in order to activate features of oem stereo. I went with aftermarket nav stereo unit.
Old Mar 1, 2018 | 02:39 PM
mrwrench's Avatar
mrwrench
if the 08 has can bus .... yes
pablocruz69
Dec 4, 2018 11:52 PM
Vertigo RT
2004 - 2008 F150
Jun 4, 2018 12:31 PM
jnye6625
21
Apr 26, 2017 08:36 PM
Y2K1TON
Nov 19, 2009 03:16 PM
