Part identification - vacuum line connector
Thanks willowbilly3. Do you know its purpose?
- Be a dead-end plug for both of those lines?
- Be an open ended plug for both of those lines?
- Connect those lines together?
I'm trying to determine if it's broken and if so what the part is so I can replace it. Right now I have vacuum on the right hand line and it's leaking (?) through to the small hole on the opposite side of the rubber piece. I have no vacuum on the left hand line.
I took the rubber piece out of the engine and now I'm thinking its some sort of connector that is supposed to be plugged into something.
In fact, I think it might be for plugging lines into a 2 port vacuum control valve. The channels go straight through the rubber so there's no way it was meant to be a plug.
I'm starting to think putting the vacuum lines back to stock is not in the cards for me. The current setup looks nothing like the vacuum diagram I can find for the 400 or the 351M. I don't have any vacuum control valves at all coming out by the thermostat. I don't have a smog pump. I don't have the fuel tank evap system. I don't have a charcoal canister. I don't have the AIR bypass valve and I don't have the OEM air cleaner (which I think encompasses a lot of the parts of the vacuum diagram).
I guess it might be time to just do the EGR delete with a new spacer plate since what I have now looks like a hacked up mess from the PO.
The Terrible Blob
03-10-2014 10:56 AM
BigBlue92
05-24-2011 10:09 AM
