rear leaf spring number help
Old Feb 26, 2018 | 02:53 PM
grumpyinme.'s Avatar
grumpyinme.
Took some numbers of a pair of f450 leaf springs,tried to look them up and came up with a bunch of other parts. F5TA BA 2530 BEO hope someone can figure them out.thank you for any help, they are factory stamped
Old Feb 26, 2018 | 03:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation Rear leaf spring "ID Engineering" number help
You cannot "look up" this F5TA-BA number, because it's the ID engineering number stamped on the leaf, it is not the part number.
In order to get the part number, a Master Cross Reference Catalog is required to cross this engineering number over.
Who on FTE has any? I do, but I loaned them out, so you'll have to contact a Ford dealer to get the info.
But once you get the part number, what will it tell you? Nothing, because after 1981, the load rates for springs are no longer listed in parts catalogs, so all you can get are its applications.
Old Feb 27, 2018 | 07:05 AM
grumpyinme.
Thanks for the info
skinner2008
Jul 6, 2019 04:13 PM
quesey
Jan 25, 2017 06:47 PM
mj_355
Jan 19, 2014 06:53 AM
Big Sky
Jun 21, 2013 01:55 PM
wizardsr
Jun 26, 2009 07:44 PM
