4 Break Downs in 10 Miles... Happy Ending though...
we were here last year at the same time just before I retired from the military. Also it is before spring break, and before the crowds at the beach. Weather yesterday was 74 degrees, today is supposed to be about the same.
The view this morning just after sunrise.
Our dogs love the water.
I still have my original boots on my '99 F350. Which brand/site are a good source? My boost pressure barely gets up to ten with normal driving, unloaded, even with a moderate acceleration to around 2500 RPMs. What is normal? The only thing I've done is bigger exhaust, 6637 mod, and Edge programmer set to level 1 "tow mode."
Hey Sous, have a look at this: https://www.dieselsite.com/dieselsit...boosthose.aspx
One thing I did to combat this problem on my old '02 was to put a third clamp in the middle of the boot as it comes off of the spider to keep it from balooning and expanding.
Stewart
That's pretty simple in thought! @Riffraff Performance needs to sell these wire holder things too. Put 'em on with three little dabs of JB Weld to permanently affix them and problem solved.
Stewart
Stewart
Stewart, you had a 3rd clamp on the boot between the spider surface and the CAC tube surface? This might be a 3rd line of defense and fairly cheap. Will probably get a 3rd clamp for the driver side too, my OCD would not like non-symmetrical spider connections.
These threads are always odd to me. I ran Riffraff boots at 35psi for 140k miles and never had an issue. Try tightening them down a little more. The clamps aren’t so much about a torque value as it is about a feel. You’ll know when they are tight enough, they won’t blow off
I have tightened them so much that I could see the metal shavings falling down out of them.
Stewart
I've been using these for about 8 years now with only one blowoff and that was due to a loose clamp:
https://www.dieselsite.com/dieselsit...tercooler.aspx
https://www.dieselsite.com/1999-2003...erbootkit.aspx
They also sell a straight boot for the 6.0 IC swap that I bought a couple of years ago when I did my swap (they also sell it as a kit too: https://www.dieselsite.com/dieselsit...kitfor73l.aspx)
Since I have the RR plenum inserts I have t-bolt clamps on everything (https://www.dieselsite.com/springt-boltclamps.aspx): IC boots, spider boots, and plenum boots. 60 in-lbs and I've only had one blowoff in 8 years and that was near WOT going up a short on-ramp getting onto the freeway. Just my .02
NOTE: The longer boots make it an exercise in patience when removing and (especially) re-installing the CAC tubes unless you have a 6.0 IC, then it's a little easier.
edit darn update what the heck did we change the forum for again?
#28
#29
So is blowing the boots a stock pipe issue? Assuming of course everything is tight. I have a Banks IC and they have a lip pressed into them from the factory. Based on what I'm reading is designed to help prevent the problem...
#30
