3g Alt
Old Feb 24, 2018 | 08:16 AM
waine5's Avatar
waine5
Question 3g Alt
Swapping my 2g for a 3g Alt. Can I just tie into the regulator? (with proper procedure) Will I be able to use existing ammeter? Tks
Old Feb 24, 2018 | 09:13 AM
Franklin2's Avatar
Franklin2
Since you have a 2g already, you should already have the red/green and yellow wires to your alternator correct? That should be a direct transfer of wires to the 3g.
You really should not use the original battery wire. The 3G has a lot more output, and can melt your original wiring(Since you have a 2G, You have 2 output wires correct?). I would hook the original wires up to the output, and also run another heavy wire directly to the battery like your picture shows. Make sure if you are adding any heavy loads, that you tie in where the heavy wire goes to the battery, and not anywhere else in the harness.
Old Feb 24, 2018 | 09:27 AM
waine5's Avatar
waine5
Red face connecting
sounds good. I'll update in a few with the now photos. What about the gauge and idiot light in the dash? Will they hold up to the upgrade?
going to connect into these.
Old Feb 24, 2018 | 11:19 AM
Franklin2's Avatar
Franklin2
If you have a idiot light in the dash, that will work fine. That is where the green/red wire comes from that hooks to the alternator. If you have a factory ammeter gauge, it will not work properly( most never did anyway).
Old Feb 24, 2018 | 02:47 PM
cadunkle's Avatar
cadunkle
Just run a new 4ga charge cable to the battery. You can tie the sense wire into that on the alternator if you're lazy but really you should run that back to the battery as well. Then tie in your key on 12v and you're golden. Very easy swap.
Old Feb 27, 2018 | 05:16 PM
waine5's Avatar
waine5
I did as said and the alt bogs down start to squeaks belt starts to wobble. Anyone know what I did wrong? I disconnect the yellow and runs smooth but doesn't put out any juice. Will this truck run without the battery hooked up?
Old Feb 27, 2018 | 06:40 PM
waine5's Avatar
waine5
Question follow-up
Old Feb 27, 2018 | 06:43 PM
kh0432's Avatar
kh0432
i had the same problem on startup when the alternator was trying to put out a lot of amperage. Installed a soft start regulator ( comes on slowly with a delay ) and solved the problem. I see you're in Nashville. Check your local listings for Automotive Electric Shops. Find someone who rebuilds alternators and have them change your regulator. Just tell them you want one with soft start and they'll know what you mean. If you can't find someone locally here are some part #s.
Transpo F795
Ford GR814
You can actually find it on Amazon if you want to install it yourself.
Old Feb 27, 2018 | 06:48 PM
waine5's Avatar
waine5
Thanks. Would have no idea. I thought I was going to burn the thing up.
Old Feb 27, 2018 | 07:02 PM
kh0432's Avatar
kh0432
DO NOT RUN ANY COMPUTER CONTOLLED VEHICLE WITH THE BATTERY DISCONNECTED. That’s an old school test people used to do to see if the charging system was working. It’s always been an inaccurate way to check because you may be getting enough output to run the ignition but if the amperage is low it won’t put out enough to handle accessories and charge the battery. The problem with disconnecting the battery with electronic ignition and various computers is that you could get a voltage spike when you take the battery cable off and fry some big dollar parts.
Old Feb 28, 2018 | 10:44 AM
Wagonboy's Avatar
Wagonboy
The correct voltage regulator will be white in color, Like this one
Motorcraft Alternator Voltage Regulator GR-814 Taurus Sable 1994-2000
See post #12 in the following conversation:
https://www.ford-trucks.com/forums/1...lternator.html
Old Mar 6, 2018 | 10:52 AM
waine5's Avatar
waine5
Tks for the info. I'm having issues finding one. Reading the thread now.
Old Mar 10, 2018 | 08:18 AM
waine5's Avatar
waine5
I tried the soft start alt reg. (tks btw) It worked for a couple days. Now its back to the squealing. I'm sure it's the same problem... when I disconnect, it doesn't make the noise. Whats my next line of action to fix this @#$@#$. It's driving me bat $#!^ crazy. BTW the alt guys said the alt is pushing 105 amps. The old alt was a 1g and all connection are correct, I even doubled up on the ground.
Old Mar 10, 2018 | 08:55 AM
FuzzFace2's Avatar
FuzzFace2
First I would check the belt tension and that it is not glazed.
It could have gotten glazed before the soft start was installed.
If the belt is ok then I am no expert but I would say the "soft" part is not working.
Dave ----
Old Mar 10, 2018 | 10:19 AM
kh0432's Avatar
kh0432
Also make sure that the alternator isn't staying at high current output caused by overcharging or a low battery demanding a lot of current. Since it fixed your problem when you first installed it, the regulator may have failed. Also a grounded rotor in the alternator could cause it to overcharge and also low voltage on the A+ terminal will.
