Stalling
Old Feb 23, 2018 | 11:52 PM
Obs7.3Powerstroker's Avatar
Obs7.3Powerstroker
Stalling
I’ve got a 1996 F-250, mostly stock ( cold air, 3” down pipe, 5” straight pipe, and ts six position). The problem I’m having with is that if I get into the gas it takes off strong, but it’s powers seems to fall away and lose its guts. I kinda think it feels like it’s is out running it’s fuel but this is just a logical guess. Is it possible for stock injectors to do this? it does this on all hp settings, the higher the setting the more stall. It will even do it slightly on stock.
Old Feb 24, 2018 | 12:17 AM
Hit Man X's Avatar
Hit Man X
Fuel filter?
Old Feb 24, 2018 | 12:23 AM
Obs7.3Powerstroker
I have only owned the truck for less than six months, haven’t gotten around to change it out. Will do on next oil change. Unless it could be related to the problem.
Old Feb 24, 2018 | 08:08 AM
oldbird1965's Avatar
oldbird1965
How many miles?
Old Feb 24, 2018 | 08:16 AM
Talyn's Avatar
Talyn
change the fuel filter and check the fuel pressure on the schrader valve while its running. it's right there on the fuel bowl. just use a tire gauge you're not worried about destroying.
Report back findings.
They will run at .. i wanna say 45+
But you wont have any power if you really romp on it. You want 65-75.
Old Feb 24, 2018 | 09:28 AM
Obs7.3Powerstroker
It has 215k miles
Old Feb 24, 2018 | 10:20 AM
oldbird1965
Change the fuel filter and if its black then you probably need new injector O rings and/or injectors rebuilt.
Old Feb 24, 2018 | 11:42 PM
Obs7.3Powerstroker
Any preferred brands?
Old Feb 24, 2018 | 11:56 PM
Obs7.3Powerstroker
I have never changed out the fuel filter on this truck. How do you do it?
Old Feb 25, 2018 | 06:55 AM
ReBilld's Avatar
ReBilld
There is drain valve on the passenger side of the fuel bowl. It has the little yellow handle. Before you open the drain valve, look down between the fuel bowl and the glow plug relay and make sure the small rubber hose is connected to the bottom of the drain valve. The hose runs forward to a steel tube that runs down the front of the block. If it's not connected to the bottom of the drain valve, the fuel you drain from the bowl when you open the valve will run into the valley of the engine and make a mess. You can see the yellow handle of the drain valve in the closed position in this picture........
If your filter cap is made like the one in this picture, a large screw driver can be used to remove the cap. Some caps are made with a square hole in the top that a half inch drive ratchet will fit in for removal. A new cap and o-ring will come with the new filter depending on which brand you buy, but some just come with a new o-ring and filter element, and you snap the new element to the bottom of your cap. I like the Motorcraft filters myself. In this picture note the position of the drain valve handle. It is in the open position........
Old Feb 25, 2018 | 07:07 AM
Talyn's Avatar
Talyn
Omg guys, just because the filter is black doesn't mean you have bad o-rings.
When the FUEL is black you have bad o-rings or you have algae.
Old Feb 25, 2018 | 10:14 AM
madpogue's Avatar
madpogue
So how does the filter get black unless the fuel is black?
Old Feb 25, 2018 | 04:23 PM
Talyn's Avatar
Talyn
It's a filter. It filters out the crap.
Mines black every time I change it, I have no o-ring leaks.
Then again, I change mine every 2 years.
Old Feb 25, 2018 | 04:58 PM
madpogue's Avatar
madpogue
Hm, maybe I've been lucky about where I buy fuel, but ours have never gotten more than brown. In any event, if the OP's filter is... dark... he should replace it and re-test.
Old Feb 25, 2018 | 05:01 PM
Talyn's Avatar
Talyn
yeah. I've had algae too, and you'll pump it out of the ground to your truck, it just might not grow.
