3.31 rearend
Old Feb 23, 2018 | 05:55 PM
ford2017diers's Avatar
ford2017diers
3.31 rearend
Just bought a 2017 F150 crew 5.0 6-speed witha 3.31 rearend in it, towed my Polaris Ranger for the 1st time and I am not happy, driving 80 mph on the interstate it wont shift out of 4th unless going down a hill. What options do I have can it be adjusted in any way or can I upgrade to a 3.55 or 3.71?? Any ideas on cost to do that? HELP!!!
Old Feb 24, 2018 | 12:17 AM
HRTKD's Avatar
HRTKD
My '07 Nissan Titan would pull my Polaris Ranger at 85 MPH just fine on the flats in 5th gear. But rolling hills would put it down into 4th for sure. I subsequently found out that the tires on my ATV trailer were only rated for 65 MPH. My Titan had the 3.36 rear end with a 5.6L engine and 5 speed transmission.
You could slow down and it would likely stay in a higher gear. My Ranger 900XP was like a parachute behind my truck, but I did have a glass windshield in mine.
My F-350 just laughs when pulling the ATV.
A tuner might help give the engine a bit more power and that might reduce the hunting of gear. My Titan was custom tuned with headers and it could chug away at lower RPM without bumping down a gear. But that was hard on the transmission.
I would think that the next most cost effective solution would be to regear. But if you're 4x4 then it will cost at least twice as much as 4x2.
Old Feb 24, 2018 | 12:19 AM
mrollings53's Avatar
mrollings53
You shouldn't be driving that fast while towing. Adjust your driving habits before complaining about your truck.
Old Feb 24, 2018 | 01:14 PM
Clubwagon's Avatar
Clubwagon
If you are going to tow somewhat regularly I would switch to the 3.73. The 3.31 is a lousy gear for towing.
Your towing speed should suit your abilities, the road and traffic conditions and the capabilities of your equipment. When towing out west I frequently tow at 80. But I have more than half a million towing miles and my truck and trailer are more than capable. Most of the time I travel a couple of miles per hour faster or slower than traffic.
Old Feb 24, 2018 | 03:42 PM
wrvond's Avatar
wrvond
The least expensive solution is to slow down. It takes a lot of power to push through the air at 80 mph. Try 60 along the same stretch and see what the truck does.
If that solution is unsatisfactory to you, then re-gearing is your next best solution. I wouldn't waste time with the 3.55, that's not enough difference to provide any meaningful performance gain. I run 4.10 with a much more powerful engine and find it works better than anything I've had to date.
Switching to 3.73 will cost between $1000.00 and $1500.00 to have it done by a shop if I'm not mistaken.
Good luck.
Old Feb 24, 2018 | 07:05 PM
ford2017diers
REALLY,, slow done to 60?? Not an option I am not retired yet I traded a 2013 3.5 EB-- 6 speed and I thot it had a 3.55 in it but I am not sure, it would stay in 5th and would run in 6th on the flat ground, but the mileage wasnt good(8mpg) .. Anyway I will have to check into changing things out, I dont pull all the time but I cant handle it staying in 4th gear on flat ground. the sales guy said the 3.31 would be fine but I should have known better.. It was my bad..
Old Feb 24, 2018 | 07:33 PM
thatdarncat's Avatar
thatdarncat
I dont want to sound like a smarty pants here, but please slow it down, 80 is way to fast for towing, baby your engine to 60 and it will take care of you in the long run.
If your trailer tires are smaller they are going even faster!
I had a 7.3 F-350 Powerstroke and always pulled around 65...sometimes I would look down and see 70 and would coast it back down to 65.
Look at it this way: Sure youre in a hurry, but if youre out there hauling *** and hurt or kill someone while towing while over or at the upper end of the speed limit , you will have a very hard time convincing a jury that your weekend jaunt was worth all of that while you showed no regard for prudence whatsoever.
Slow down a little and dont let a lawyer get everything you have worked for.
Old Feb 24, 2018 | 09:19 PM
Jo7.3's Avatar
Jo7.3
I'm only 20 and don't drive 80 empty or loaded lol. That's just plain dangerous, especially on some roads where I live. Even on I-95 and I-295 near Richmond the speed limit is 70 at the most so I'll go 75 if empty. Towing any weight I'll stay around 65-70 depending on what I'm towing. Just slow down...it's safer and saves gas too.
Anyways, if you slow down and still want more power, then I'd regear to 3.73s at least. Hope this helps
Old Feb 24, 2018 | 11:22 PM
Rustofer's Avatar
Rustofer
Even if you move to a higher rear-end ratio you might just be moving the gearing from your trans to your diff, and the engine will continue to rev where it needs to to make the power. It doesn't have the low-end torque of the EB.
Old Feb 25, 2018 | 06:04 PM
dnewton3's Avatar
dnewton3
I'm not ready to condemn him for towing 80mph yet; it would depend on where he's doing it, the equipment, etc. If he's out west, open interstates, then most everyone is going that fast. Further, it would depend on the tires he has; some now are actually rated at 81mph (I just got some D rated tires with 81mph rating). Conditions of bearings, size of wheels, etc. It may not be as dangerous as we'd first believe. Or it could be stupid. Don't know enough to make a call on that yet.
Here's the problem he has; the 5.0L is a great motor, but it's not known for low end torque. Having 3.31 gears is a very tall ratio. Wind load is greatly increased as you speed up. It's just not going to pull easily at that speed with those gears; no other way around that. You truck will certainly pull a load. It's just not optimized for towing.
About the only thing you can do is swap gear to 3.73 set. Different gear set will assist for sure; it's a torque multiplier. For any given tranny gear, a lower diff gear (higher numerically) will provide more thrust force, but over a narrower speed range.
Old Feb 26, 2018 | 03:34 PM
seventyseven250's Avatar
seventyseven250
What's wrong with it being in that particular gear? Regearing to 3.73 (or whatever) isn't going to change where the engine needs to rev to make that power.
I towed a 7500lb travel trailer with my 2012 with 3.31 gears and it spent most of it's time in 5th gear at slower speeds than you are talking about, downshifting to 4th for hills. I'm sure if I had the 3.73's it would have been in sixth, and downshifted to fifth, but so what? Engine speed is what matters to me, not what gear I am in.
So you bought the "wrong" truck, but it's handling a pretty tough situation relatively well. 80 MPH towing anything is relatively extreme for a half ton with a gasoline engine. Maybe relax a little and either slow down or live with the situation you are creating yourself. This isn't an equipment issue.
Old Feb 27, 2018 | 03:30 PM
Diamnd1's Avatar
Diamnd1
I went from 3.73 to 4.30 in my F250 4x4. Towing my TT~9000lbs, the trans would struggle to stay in OD. Did alot of miles with OD locked out. Since the swap, I can cruise at 70 in OD with no problem and will only downshift when climbing a long, moderate to steep hill. Swap cost $2500 but had a Ford dealer do the swap. Best mod I have done to the truck besides the 6.0 trans cooler. Just because the trans cooler wasn't as expensive!!!
Old Feb 28, 2018 | 09:44 PM
scott91370's Avatar
scott91370
Very odd because my 2015 will tow my 3800# travel trailer at 70 in high gear and I've got the 3.31 as well. Unless I'm in the Rockies in Colorado it will always find high gear.
I'm not sure why people say it's lousy. Sure it may have been 15 years ago when you had 4'gears but with the 6sp and now 10sp transmisssions the need for lower ratios isn't as critical.
Old Mar 1, 2018 | 07:27 AM
2012 F150 5.0's Avatar
2012 F150 5.0
Scott,
Do you have 6 speed?
Old Mar 1, 2018 | 08:12 AM
scott91370's Avatar
scott91370
Originally Posted by 2012 F150 5.0
Scott,
I do......
