Dove-c heads
02-22-2018, 07:23 PM
on
Dove-c heads
Could anybody tell me what pistons to use to get close to 9.5-1 compression ratio with dove heads at zero deck height.
02-22-2018, 11:00 PM
zero deck, and 9.5:1?? You sure? you need d3 heads. Something with a 25cc dish. If you are actually at zero deck. Most 460 builds aren't there.
02-23-2018, 09:24 AM
on
I apologize i meant stock deck height, stock deck height, stock crank, rods, and dove heads. Trying to get as much compression/power with stock parts and pump gas.
02-24-2018, 08:05 AM
what block? d1ve, d9te, etc? usually the deck comes in at 0.030 in the hole. some configurations were more, some were less.
02-25-2018, 05:19 PM
on
04-08-2018, 08:36 AM
Unless someone changed it, deck is probably 0.020+ in the hole.
somethingclever
02-28-2009 01:28 PM
djtuna
11-14-2005 07:11 PM
Mudman
09-30-2003 05:36 PM
fordzman
08-29-2003 10:53 AM
boone444
11-22-2002 06:00 AM
