Engine stall help
Old Apr 13, 2018 | 02:27 PM
  #76
52 4x4's Avatar
52 4x4
A fuel pump pressure and volume test? - Bob
Old Apr 13, 2018 | 04:45 PM
  #77
Gicknordon's Avatar
Gicknordon
That is kind of what I am leaning towards. I want to eliminate thw carb first since thar won't cost me anything except time.
Old Apr 15, 2018 | 08:43 PM
  #78
Iowa F1's Avatar
Iowa F1
The only thing I have to add to this, are All the fuel fittings tight? Remember, it's easier to suck air than to pump liquid. You can suck air and not have a fuel leak.
Old Apr 15, 2018 | 08:57 PM
  #79
topmoo's Avatar
topmoo
You might have a pinhole in your float. Mine were fairly new too and sitting for months this stuff we now call gas actually somehow corroded my floats, both had pinhole leaks and would fill with gas. Something to check... Good luck.
Old May 4, 2018 | 05:21 PM
  #80
Gicknordon's Avatar
Gicknordon
So I think I got this issue all settled now. I ended up getting a fuel pressure regulator and that cured my issue of fuel overflowing from the carb. I had talked to a guy that said that the edelbrock fuel pumps are known for the regulating spring weakening when the engine heats up, allowing more fuel pressure than what is necessary. I think I might replace that pump too because I don't trust it anymore.
For some reason, I then had a bunch of issues with the tuning of my carb. I swapped my dads carb on like I mentioned earlier, and it ran perfect with his. I tried rebuilding my carb again, but sill could not get it to run right. I ended up buying a new holley ultra HP carb, and now it runs just about perfect. Just need to mess with the secondary accelerator pump a little and it will be perfect.
Thanks for all the help and advice from everyone!
Old May 4, 2018 | 08:28 PM
  #81
abe's Avatar
abe
Good to know! Especially since we've had temps in the high 80's!
hdscott2018
2004 - 2008 F150
Apr 6, 2023 09:23 AM
jjkoontz
Modular V10 (6.8l)
22
Aug 15, 2019 09:55 AM
dunerunner
Modular V10 (6.8l)
Mar 31, 2010 09:02 PM
fordthug
Bronco II
Jun 30, 2007 09:19 PM
f150-az
1997 - 2003 F150
Jun 2, 2003 09:20 AM
