I recently bought a 17 F250 4x4 long bed 6.7. It is used with 13k on it. I was reading an interesting post on here yesterday and it got me thinking, what are the options on my truck? I bought it from a Nissan dealership so I didn't exactly get a Ford window sticker. I work for an autobody shop so I tried looking it up on Alldata but it doesn't specify what my truck came with. I did the vin decoder on this site and I got some ifo but not all. What are my options to find out... my options?
Pick your base level (XL, XLT, ect...), Then look at the packages and what comes with it and match to those you can ID, then print that out and you will have a list of stock and add-ons. Some packages are the only way to get an item. For example, if you have a Lariat with LED headlights, you have BLIS, LED, Lariat Ultimate. Play around with the site, you should get close to the options you have.
GVWR is posted on your door jam, as is the axle code and some other info that may help ID what you got. Axle code gets you the ratio and if it's an electronic locker.
Funny you post this, I was wondering the exact same thing. I have the same axle code and am looking up what axles/ratios they are.
Edit******
Looks like we have the "31 - 3.31 non-limited slip". Not quite sure if this is even good or not. I feel like I'd be better off with a higher ratio but, don't really want to change the front and the rears.
Edit******
I called Ford and they said I have the 3.31 Dana non limited slip. However one of the vin decoder sites here said I have 373's and my truck sure feels like it. IDK. The other vin decoder listed on here can't find my window sticker.
Here you go, this is what your sticker says. Not much...
SUPER DUTY
2017 F250 SRW 4X4 CREW CAB
XLT 176" WB STYLESIDE
6.7L POWER STROKE V8 DIESEL
6-SPEED AUTO TRANS
EXTERIOR: OXFORD WHITE
INTERIOR: MEDIUM EARTH GRAY
VIN: 1FT7W2BTXHED69155
FUNCTIONAL
4-WHEEL ANTI-LOCK DISC
BRAKING SYSTEM
HILL START ASSIST
JEWEL EFFECT HEADLAMPS
MANUAL LOCKING HUBS
MONO BEAM COIL SPRING FRT
SUSPENSION W/STAB BAR
INTERIOR
1TOUCH UP/DOWN DR/PASS
WIN
60/40 REAR BENCH W/FLIP-UP
/FLIP-DOWN W/HEAD RSTRNT
/UNDER-SEAT STORAGE
AIR COND, MANUAL FRONT
CLOTH SUN VISORS
CRUISE CONTROL
OUTSIDE TEMP DISPLAY
PARTICULATE AIR FILTER
POWER LOCKS AND WINDOWS
TILT/TELESCOPE STR COLUMN
EXTERIOR
BOXLINK
BUMPERS - CHROME
GRILLE - 2-BAR, CHROME
LOCKING REMOVABLE
TAILGATE
W/LIFT ASST-NA W/BOX DLT
PICKUP BOX, TIE DOWN HOOKS
-NA W/BOX DLT
REAR PRIVACY GLASS
SPARE TIRE AND WHEEL LOCK
-NA W/BOX DLT
TOW HOOKS
TRAILER SWAY CONTROL
SAFETY/SECURITY
ADVANCETRAC WITH RSC
AIRBAGS - SAFETY CANOPY
DRIVER/PASSENGER AIR BAGS
PERIMETER ALARM
SOS POST CRASH ALERT SYS
OPTIONAL EQUIPMENT
PREFERRED EQUIPMENT
PKG.603A
6-SPEED AUTO TRANS
LT275/65R18E BSW ALL SEASON
3.31 RATIO REGULAR AXLE
10000# GVWR PACKAGE
ELECTRONIC SHIFT ON THE FLY
50 STATE EMISSIONS
JACK
