Sponsored by: Real Truck
manual hub question
Old Mar 5, 2018 | 02:26 PM
00t444e's Avatar
00t444e
4x4 won't work without both hubs locked, since the front has an open differential it will just spin the axle shaft on the hub that isn't locked.
Old Mar 5, 2018 | 03:05 PM
redford's Avatar
redford
FTE Leadership Emeritus
One locked hub and one defective or missing hub doesn't work.
Remember, the stock front differential is an open differential. It will send the power to the axleshaft that is spinning the fastest. In your case, that will be the axle with no hub. No power will get transmitted to the wheel on the ground.
If you've ever fragged a front hub you would see that 2WD works better than 3WD.
v10hawkeye
Apr 30, 2015 03:49 AM
Titan12345
Aug 20, 2011 10:09 AM
MonsterTruck\m/
1966 - 1977 Early Broncos
Jul 18, 2011 09:59 PM
VodkaMan
Jun 10, 2009 10:38 PM
srauner
Mar 20, 2008 09:55 PM
