Been lurking as a non-member for several years! Enjoy the threads and the knowledge. Glad I joined! So, I did a search on the forum here and cannot find anything about the error code P2568 (Direct Ozone Reduction Catalyst Temperature Sensor Circuit Range/Performance).... Doing a search on Google, I believe this is a faulty sensor near the catalytic converter (and I think there's 3 sensors near the converter). I got under the truck and checked all the wiring and connections that I could. Anyone have any knowledge with this code? Thanks again for adding me as a member!
Yessir. I will get it read again, but i was with the tech when he read the code. I will run it back up there and have it read again. Thanks a lot for looking into!
Maybe the moderator should post this to the 2011-2016 6.7 forum. It's likely related to the DPF (not a catalytic concpverter) and those sensors, or comparing sensors, might need a new NOx sensor or EGT probe? If reading it at Ford, can't they provide a recomendation on what it is, they should be able to tell you.
