Interior Refresh - Whats missing?
Old Feb 18, 2018 | 11:59 PM
cmcdonald375's Avatar
cmcdonald375
I am in the process of pulling all of the carpet, seats and headliner out of the 2001 Ex... Here is what I am planning on doing and want to make sure I am not missing anything stupid:
1. Carpet Deep Clean / Steam Clean (its nasty thanks to previous owners kids)
2. Sound Deadening - Dynamat / FatMat type on roof, floors, and door panels
3. Additional Carpet padding insulation in panels and doors
4. Rear mounted inverter and cell booster (there is a lot of room back there!)
5. fix broken mounting clips for rear panels.
6. LED conversion for all interior lights
7. Clean / Lube seat belts (still looking for a better way to fix these so they retract)
8. New Speakers
Is there a filter or anything i should replace on the rear AC?
There seem to be a lot of holes that show through to the ground that I am not sure what are for... I think i should plug / fill these?
Anything I am missing?
Old Feb 19, 2018 | 05:49 AM
Oldguyfl's Avatar
Oldguyfl
The holes are where the seats bolted in? Sounds like a fun project.
Old Feb 19, 2018 | 06:58 AM
High Cetane's Avatar
High Cetane
My recent "interior refresh" included prepping & refinishing all the seat frames.
It was considerable work, but well worth it.
If you search, you might run across OGF's recent carpet thread which may be helpful.
Old Feb 19, 2018 | 08:25 AM
EXSwap's Avatar
EXSwap
You're missing #9: Posting the whole project and pictures up to FTE so we can all ogle your refreshed interior!
Old Feb 21, 2018 | 10:56 PM
cmcdonald375
Holes....
It looks like one of the seat bolts had been stripped out and they used a large class 8 bolt with a nut, and no washer...
Old Feb 21, 2018 | 10:59 PM
cmcdonald375
Picture time.....
I missed a few steps, and i was in a hurry because it was sunny and 79 degrees. Now its raining and 40....
Here is the start...
Old Feb 21, 2018 | 11:02 PM
cmcdonald375
Rear deck, some rust spots and crappy area that they patched to cover the bench seat bolts... I have second row captains chairs...
Old Feb 21, 2018 | 11:04 PM
cmcdonald375
Front with carpet, then without, then with deadening material...
Before everyone gets in a tizzy, I know you don't have to cover the whole thing to quiet the metal resonance, but i had enough, and it will help with road noise and thermal...
Old Feb 21, 2018 | 11:07 PM
cmcdonald375
And lastly, complete, roof and floor and headliner back in... and under hood.
Old Feb 21, 2018 | 11:10 PM
cmcdonald375
Now for some questions...
On the passenger side, the trim piece that covers the rear AC looks like it has some plastic holders attached to the bottom of the window frame. Mine are all busted, any ideas on replacements?
When I unplugged the audio controls from the center console, my back speakers stopped working... How to I hot wire this thing so they work all the time without the panel attached?
Any idea where to get replacement Clear/Red combo front door courtesy light covers?
Thanks!
Old Feb 21, 2018 | 11:11 PM
cmcdonald375
Here is a picture... it is the black plastic that is broken under the window..
Old Feb 22, 2018 | 12:24 AM
ShelbyHauler's Avatar
ShelbyHauler
Thanks!
From what I have seen of the audio schematic, the radio feeds the rear audio console and that feeds the rear speakers. Front speakers are powered directly from the radio. I'm guessing so the back seat passengers can use the rear entertainment system it will turn off the rear speakers? You could just insert a couple of jumpers in the rear control panel connector but I see it mentions it has an Amplifier in the control panel?
Edit: Added info
Looks like if you unplug from the rear control and jumper pin 3 to 2, and 7 to 6 you would get your rear speakers working. But as you are driving 2 speakers (on each side) the rear volume will be lower than the front due to the amplifier not being plugged in.
2nd Edit:
The electrical diagram is a bit funky. It shows the neg speaker wires going to the amp and exiting as a pos speaker wire. Wires 5 & 12 from radio go to AMP as 3 & 7. Wires from radio 6 & 13 split and go to both AMP and Speakers. At any rate, the 1st edit should work with the control unplugged.
Old Feb 22, 2018 | 12:31 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Thanks!
I can get you the piece under the window.
The audio control work around is well documented by myself and others in the Tech Folder. https://www.ford-trucks.com/forums/9...l#post17065338
I have at least one red/white combo courtesy light on my shelf that I don't need anymore since I switched to '10 door panels. There is also an eBay seller that has them.
Old Feb 22, 2018 | 06:31 AM
1 Excursion camper's Avatar
1 Excursion camper
Look under the rear A/C box and check the floor. They tend to rust out at the very back corner.
Old Feb 22, 2018 | 09:09 AM
cmcdonald375
i would love anything you can get me... I will read up on the audio work around tonight as well. AS always this forum is a wealth of knowledge! Thanks Everyone!
