1996 f150
Old Feb 18, 2018 | 06:03 PM
ididntdoit89's Avatar
ididntdoit89
1996 f150
hello gentlemen,
it has been a while since i have posted i hope all is well. here is the deal. i replaced my 2.73 gears with 3.73 gears with a limited slip diff. my question is how can i go normal highway speeds with less engine rpms? Im thinking I need to do a tranny swap but i am not sure. my current set up consists of a I6 300i. with 3.73 gears. 2 wheel drive. eddie baure edition. any help would be greatly appreciated.
Old Feb 18, 2018 | 06:17 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What transmission do you currently have in the truck?
Old Feb 18, 2018 | 06:54 PM
Conanski's Avatar
Conanski
And what are your normal highway speeds?
And what size tires do you have?
Old Feb 18, 2018 | 06:59 PM
88n94's Avatar
88n94
Any transmission that would have come in a 1996 would have an overdrive, I think, with roughly 0.80 gearing. The only transmission that would help would be a 6 speed double overdrive, some odd thing I read about with a separate clutch housing. If you wanted slower engine RPMs you defeated your purpose with that gearing.
Old Feb 19, 2018 | 04:05 AM
Bruce W.'s Avatar
Bruce W.
Originally Posted by ididntdoit89
hello gentlemen,
Check out gearvendors.com. See if they have one for your particular app. They are not cheap...but they are GOOD! I've been running one for about the last 100K miles...trouble free...and, in another 200K or so, it will have paid for itself in gas savings and reduced engine wear! What a deal!
Old Feb 19, 2018 | 06:55 AM
ididntdoit89
There were f350 that came with the I6. No way they were turning the same rpms that my f150 is now turning. It’s got to have something to do with the tranny. I can’t think of any other explanation. I currently have the Mazda transmission. Engine is screaming at 55mph. I can’t tell you guys the exact rpms as I do not have a tach.
Old Feb 19, 2018 | 08:41 AM
Thinlizzy13's Avatar
Thinlizzy13
Going from 2.73 to 3.73 would increase your RPMs. Going back to a numerically lower rear end would lower your RPM’s. Any transmission for the I6 w/OD is going to have roughly the same OD ratio.
At 55 with stock tires your setup should be around 1900-2000 rpm. Is it possible that your rear end is geared higher than you think?
White Mountain Goat
Offroad & 4x4
Mar 6, 2014 08:18 PM
shooter23
Offroad & 4x4
48
Sep 16, 2010 12:41 AM
DonnyG77
15
Apr 21, 2009 03:59 AM
robertbourque
May 2, 2007 06:12 PM
whitety1000
Feb 16, 2006 10:15 AM
