4:11 gears
Old Feb 15, 2006 | 03:02 PM
whitety1000's Avatar
whitety1000
4:11 gears
I have a 84 F-150 with the straight 6 and a standard overdrive transmission. I have really high gears in the rearend right now I think they are 3:00. I have a posi unit out of another 9" that has 4:11's. I needed to make the switch for two reasons, One I will be hauling a car close to 300 miles, I figured the lower gears would help. Two, a posi unit would just kick ***. My question is what kind of a difference will it make in both my pulling ability and how badly will it effect my RPM's at 70MPH?
Old Feb 15, 2006 | 11:06 PM
85F_150driver's Avatar
85F_150driver
http://www.wallaceracing.com/Calculators.htm or http://www.actionspeedparts.com/tires.html
use this link and it will answer all questions. as long as you tranny has overdrive the 4.11's will be exelent but if no overdrive it will wind out at about 65.
Old Feb 15, 2006 | 11:28 PM
Bdox's Avatar
Bdox
If you go from 3.08 gears to 4.11, your rpm at a given speed will be about 25% higher.
Old Feb 16, 2006 | 10:15 AM
Sycostang67's Avatar
Sycostang67
If it spins too high, you can always get larger tires to bring it down.
