Sponsored by: Auxito
Blocking off the PCV hoses.
Old Feb 18, 2018 | 04:01 PM
1999-F150's Avatar
1999-F150
How bad would it be to block off the pcv system. I have a leak at the pcv. I don't have the money or time to fix it at the moment. Can I just plug the pcv hose? Thanks for the help.
1999 F-250 5.4 4x4
Old Feb 18, 2018 | 05:14 PM
steve(ill)'s Avatar
steve(ill)
PCV is positive crankcase vent... it sucks all the bad fumes out of the motor and keeps any buildup pressure to a minimum...... NOT a good idea, but you can plug the suction end ( valve end) of the PCV, but the motor end should be able to vent out so pressure does not build up........ Why not cut the hose and use a plastic sleeve between the two halfs ? Or is the valve itself broke ?
Old Feb 18, 2018 | 06:25 PM
1999-F150's Avatar
1999-F150
The two lines are badly decitergrated up the plastic line.
Old Feb 18, 2018 | 06:48 PM
530ktmpilot's Avatar
530ktmpilot
Literally $10 in parts and 30 mins of time. If you want to rig it instead, wrap the hoses with electrical tape to stop the leaks and keep it together.
Old Feb 20, 2018 | 12:36 AM
Lime1GT's Avatar
Lime1GT
pick-a-part wreckers might give hoses to you for nothing. They're more interested in metal and component parts.
Old Feb 22, 2018 | 01:02 PM
Bluegrass 7's Avatar
Bluegrass 7
You can block the PVC hose but not the valve cover vent.
If you do and leave it that way, you invite build up of crankcase pressure that leads to oil bleeding from gaskets and Seals, and engine sludge build up over time.
Fix it right.
Good luck.
KG Excursion
Modular V10 (6.8l)
Jan 24, 2018 08:44 PM
1999-F150
1997 - 2003 F150
Jan 20, 2018 10:05 PM
NS70250
33
Aug 17, 2016 11:50 AM
Proxymatic
May 14, 2008 10:01 AM
baitboy
Jul 9, 2001 03:52 PM
