Horn location - '85 E150
Old Feb 16, 2018 | 10:11 PM
CottonTexas's Avatar
CottonTexas
Did a search, & came up with nothing, so could one of y'all please tell me where the horns are located on my '85. I've looked in all the obvious places, and still can't seem to find 'em. TIA, Cotton
Old Feb 16, 2018 | 10:32 PM
85e150's Avatar
85e150
Try driver side on the core support behind the grill. **CORRECTION BEHIND CORE SUPPORT SEE POST 3.
Old Feb 16, 2018 | 11:26 PM
annaleigh's Avatar
annaleigh
This diagram came from a Ford service manual for my 85 E150
You will find that same manual here
https://www.ebay.com/itm/FORD-1985-B....c100677.m4598
Old Feb 17, 2018 | 09:52 AM
CottonTexas
Thank you for the helpful replies! Sadly, it looks like my horns went MIA, and I'm going to have to trace back to see where the original wires were most likely cut. Thanks again, Cotton
Old Feb 17, 2018 | 11:18 AM
annaleigh's Avatar
annaleigh
I meant to say that 85e150six4mtod was spot on..
Do you have speed control on your van?
If so then if i am reading my diagram correctly, the wire color to the horn should be Blue/Yellow. That wire runs to the curved connector at the steering column.
Old Feb 17, 2018 | 01:27 PM
85e150's Avatar
85e150
Actually I misremembered that it is behind the core support. Mine stuck one day so I had some ear-numbing moments pulling the wire by the side of the road. Mine had the single horn only with no speed control.
Old Feb 17, 2018 | 04:03 PM
CottonTexas
Very informative - Thank you both!
Old Feb 23, 2018 | 02:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
13800 are the horns, 12A199 is the DuraSpark ignition module.
Old Feb 28, 2018 | 07:41 PM
CottonTexas
Many many thanks! Very helpful information indeed! Cotton
ultraranger
Mar 8, 2015 06:29 PM
Philo Beddoe
May 25, 2010 11:42 AM
tinman52
Feb 21, 2010 08:22 PM
CEHSR
Nov 4, 2007 11:34 AM
Putt
Mar 8, 2006 11:00 PM
