Throttle not working
Old Feb 16, 2018 | 09:40 AM
StrokinHer01's Avatar
StrokinHer01
every now and then my throttle will not work even all the way down. And sometimes it jumps while at a slow speed... 2001 f250 7.3... can this lead to power loss nd low mpg?
Old Feb 16, 2018 | 09:45 AM
Tom's Avatar
Tom
Moving to the 7.3L forum.
I don't think this would affect your fuel economy, it sounds like you have an electrical issue between your throttle pedal and PCM. Just a wild guess though.
Old Feb 16, 2018 | 09:57 AM
mcnance865's Avatar
mcnance865
Sounds like the Throttle Position Sensor (TPS). Pretty common issue. If you search for it, I know there are threads about it.
Old Feb 16, 2018 | 10:58 PM
LAMADMAN's Avatar
LAMADMAN
Same happened to me. I was able to remove my TPS and clean it up with contact cleaner. Been good ever since then. Make sure the contact cleaner is safe for plastic.
Pockets52
6.4L Power Stroke Diesel
Mar 29, 2013 08:25 PM
joeyd61
Mar 5, 2013 02:18 PM
Torvvald
Mar 10, 2007 06:52 AM
Torvvald
Mar 9, 2007 11:44 PM
