Metal Chop Saw Improvement
Here is the sweetest thing I have run into lately. I have been using metal chop saws for 40 years but a place in Houston, SawBlades.com sells a 14 chop saw with a carbide metal cutting blade. There is no dust, much less noise and much less cleanup. Runs at a slower speed and cuts as smooth as a horizontal band saw! The picture above is the saw cutting a ½ X 4 ½ mower blade to shorten it. He just finished cutting about 15 blades. We bought 3 for our different shops. The saw has a protected shield that opens as you lower the saw. Only thing I dont like about it is that the screw jack does not have a quick release. They have a special of $549 free shipping which comes with a roller jig. If you order one make sure you specify a steel cutting blade instead of aluminum unless you are going to cut only aluminum.
TractormanBill
TractormanBill
Thanks Mixerman ... I have a couple of old fuel oil tanks that I have to cut to
get rid of -- maybe that's the tool for it. Those old tanks, even if they've been dry for years, are famous for being possibly explosive, I know, so less sparking is good. I've been told to maybe fill them with dry ice before cutting. And be sure your Will is righteous....
I bought this one:
You'll love it. I cut all my steel for my workbenches and table in my shop with one blade. These blades are cheaper to, I use "benchmark abrasive" carbide blades. Work just as good as the brand names (20-40.00). I got my saw "openbox" on amazon for $100.00............
This is one of my next purchases.........
https://www.amazon.com/Evolution-Power-Tools-EVOSAW380-15-Inch/dp/B0046VUGSU/ref=sr_1_3?ie=UTF8&qid=1518785382&sr=8-3&keywords=evolution%2Bsaw&th=1
Thanks Mixer Man ... I'll check with my welding supply guys about Nitrogen, that
may be the way to go. A 5 lb CO2 extinguisher is amazingly pricey, unless you can buy out-of-date ones from the fire dept. The trouble with dry ice is getting enough of it through a 3-inch opening to fill the tank (with CO2). I guess with Nitrogen the problem is how to know when you've actually flushed out all the air ... maybe it comes in colors.
