Rim headlights
Old Feb 14, 2018 | 01:11 PM
hayman7561's Avatar
hayman7561
Rim headlights
How do you activate the U shaped lights around the headlights. Special feature, add on or????
Old Feb 14, 2018 | 01:16 PM
nuctrooper's Avatar
nuctrooper
They are part of the factory LED package, so that is requirement #1.
By default, they are the Daytime Running Lights (DRL). When you start the truck they'll stay off until you put it into gear, and remain on until you put it back into park. If you have the LEDs and they don't seem like they're on, find a store window front that you can use like a mirror and put the truck in gear. (or - though I advise against it - put it in gear and get hard on the E-brake and get out and look. Or, just have someone else look)
They should be on full brightness during the day with the headlights in off or auto, and half-bright at night with the headlights on or auto.
ForScan has some options to turn them off, but unless you have modified it they should come on by default.
Paul_Bukowski
2015 - 2020 F150
43
Nov 14, 2024 12:16 AM
L-ight
May 24, 2018 10:13 AM
2010FORDF350
Feb 25, 2017 03:05 PM
reddevilf150
Feb 10, 2003 02:45 PM
